Mullet Z28
09-01-2003, 02:21 PM
I'm running 1.55" diameter valvesprings. In certain spots, the head stud nuts won't fit because the springs are too wide. In other spots, they'll just barely fit but there's no way in hell a socket will fit to tighten the nut down. Please help.
I suppose I could take the "problem" springs off and install the studs/nuts first (motor is out of the car right now), but then there would be no way to take the heads off with the motor in the car. If I decide to take this route, who or where sells the type of spring compressor I need. These mofos have 600 lbs. of open pressure.
The obvious solution is a nut or bolt with a thinner head, but who sells them? That would also probably mean running bolts in the problem areas instead of studs, and then I wouldn't feel as cool.
