IgorT.455/406
06-15-2002, 06:42 PM
Hey guys. I have a set of Performer RPM heads on my .040 over 350 with about 10.3:1 CR. I also have a Crane Fireball hydraulic flat tappet cam, 224/234 duration at .050, .496/.520 lift and 114 lsa. I have a Comp Solid Roller XE280 cam, 242/248 duration, .576 lift and 110 lsa. Over my current combo, this cam is a roller step up and its solid. But I was thinking about upgrading my cylinder heads to Dart Iron 230cc ones, but am afraid they might be a bit too big for the 358. What do you guys think the motor would react like with these heads and the comp cam. Reason why I want 230 ccs is 'cause I am going to build a 406 short block by spring and want to use those heads on it. What do you guys think, go 215 cc runners maybe? I think Performer RPM is 170cc, not sure. Thanks guys!
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
