cabell84
08-27-2003, 02:37 PM
My cruise control shuts off when i hit a bump in the road. It will turn back on when i lift the brake pedal up with my foot and press resume. I know that there is some way to adjust this, but I dont know how. Does anyone have this same problem? If so, how did you fix it? -thanks.
95GRNZ
08-27-2003, 09:58 PM
Come again...? :confused:
You lift the brake pedal with your foot? :confused:
So, when you hit a bump on the road, the brake pedal goes down by itself and stays there until you lit it? Now that sure sounds interesting... :eek:
Wow...
TS
deadmeat2004
08-27-2003, 11:30 PM
i think u need to rephrase that...do u mean u have to push on the brake , let up and then hit resume?
cabell84
08-28-2003, 03:28 PM
no, the pedal doesnt sink to the floor or anything, it returns to its normal position. It just slightly moves when i hit a bump in the road, and the cruise disengages. when i TOUCH the underside of the pedal with my foot and press resume, the cruise comes back on. There is no big problem, i just drive on the highway a lot and its annoying.
95GRNZ
08-28-2003, 03:47 PM
I'm not eactly sure how the pedal is attached to the car, but it sounds like something is either loose or missing from the pedal assembly. :think:
Better crawl down there are see what's up before you don't have a brake pedal at all. ;)
TS
