Dart
08-27-2003, 01:59 AM
I have had some trouble with one of the supporting advertisers of this site and would like to bring it to the attention of the masses.
The site is Suppersport Performance.com
I recently went looking for an air lift kit and found this add at there site.
Air Lift Rear Spring Kit 82-01 Camaro
Engineered as an add-on helper spring for coil spring suspensions, AirLift are ideal for the rear coil springs of many passenger cars. It improves traction in drag racing, reduces body roll, sway and bottoming out as well as improving poor handling and braking. AirLift features an easy do-it-yourself installation with simple hand tools and takes aprox. an hour to perform. Kit includes air springs, air lines, brackets, fittings, mounting hardware and detailed instructions.
Using the Load Controller II system, you don't need to crawl under the car to inflate your air springs! Control the air pressure from the drivers seat to tailor your car's handling to current road conditions while driving. The Dual Gauge system allows you to control left and right air springs seperately and the single gauge version inflates both sprngs equally. Both kits come with an LPS to maintain at least minimum pressure in the springs at all times.
Air Lift Kit
82-01 Camaro, Z28 Load Controller II Load Controller II Single Gauge Dual Gauge
$79.99 $149.99 $219.99
It seemed like just what I wanted and the price was better than I could get localy, however when I receved the Load controler II I found that it did not include the air lift kit. If you read the discription it does not tell you that the kit is not included.
Nowhere in this add does it say that they are sold separately and it is listed in the same add as the kit.
I e-mailed them and got little help
There response was
We shipped you the EXACT product you had ordered, it was a complete package, nothing was missing, nothing was mis-represented, if you were unclear on what was included in the order you should have contacted us to avoid "any MIS-UNDERSTANDING". If you insist on returning it, there will be a 25% restocking fee, S&H is also non-refundable.
I responded back that I would respond on the camaroz28 board and there response was.
Cool, be sure to send a link this way.
Do you really want to do business with a company that treats customers this way.
Air Lift Kit
There response was
