Earls stainless steel brake line install question
G Bear
08-24-2003, 08:03 PM
How do you install the lines without drying out the brake system. I hear drying the system is not good, but the instructions says to drain the sysetm.Any advise.
Bill'sWS6
08-25-2003, 11:22 AM
I have these on mine and the system was installed without draining. Just make sure you bleed the system very well after you do the change.
Good luck
screaminss
08-25-2003, 12:48 PM
Are there any issues using the stainless steel brake lines with ASR? most of the brake kits have
a disclaimer about not for models with traction control.
Mike
Bill'sWS6
08-25-2003, 02:48 PM
Mike
There is a brake line in the kit that can't be used on cars with TC. You can use all the others and it does make a noticable difference in stoping. Which I could tell you why they don't make one thate hooks to TC?
Good Luck
