Eagle or Scat crank and rods?5.7 or 6.0 rods?mains?
96LT14u2Nv
08-24-2003, 03:52 AM
i am going to build a mild 383 for my chevelle. which of these cast cranks and I beam rods are going to be the best for my project. i am looking for around 400-450 HP TOPS.
the scat crank=$189, scat rods=$239
eagle crank=$285,eagle rods w/ARP wavelock bolts=$295
the prices arent that far off, but i just wanted to see what everyone else is running
also, should i get a 6.00 rod or a 5.7 length rod for my 383? i dont want to cut any corners.
and lastly, it is a 350 4-bolt main block.....should i get new mains to take the added power or can i just get some ARP bolts for the extra strength?
thanks guys.
DarthIROC
08-24-2003, 11:53 AM
MIld 383 I think you would be ok with a cast steel crank from SCAT or Eagle. Personally I think SCAT has a better name for cranks.
Rods, I have been looking at myself lately for my 400 project. You should go ahead and put the logenst rod you can fit in. So 6.0 inch would be better. I persoannnly like Eagles 3D rods so far because they come stroker cleared already. Plus they come with the ARP bolts.
96LT14u2Nv
08-25-2003, 12:28 AM
so, can i use the scat crank with eagle rods? can i use stock LT1 rods? how much HP is the scat good for do ya think?
DarthIROC
08-25-2003, 12:40 AM
As long as you dont get smal journal rods, or a 400 crank, any sbc rods and crank should be compatible. I dont know about the LT1 rods. But you should go ahead and get stronger aftermarket rods anyway, and get full float ones too. Frees up some hp.
The Cast steel SCAT crank I was considering is made out of series 9000 material, and is shot-peened for superior strength. I think its rated at 500-600 hp at like 6500 RPM. But I cant recall for sure.
96LT14u2Nv
08-25-2003, 01:21 AM
yeah, that is the scat i was looking at. i think i might just go with an all scat setup. who knows. but thanks for all the input/suggestins darth!
DarthIROC
08-25-2003, 07:15 PM
No problem. I think I just lean alittle more towards eagle rods, cause Im looking to build a 427 Small block, so that means alot to me that the Eagles come stroker clearanced. But Im sue Scats rods are great too.
RicocheT
08-26-2003, 12:58 AM
Just a heads up.. check the thrust part of the crank if you go with eagle, They apparently had a bad batch of cranks that were not machined properly. They need to be polished to almost a mirror finish. The one i recieved and another a friend recieved had grooves cut in the thrust part of the crank. Which of course just chewed up the bearing :-)
Just trying to save you some trouble
96LT14u2Nv
08-26-2003, 01:48 AM
thanks for the heads-up man. i have strayed away from the eagle now simply b/c nobody has really said that one is better than the other.ill use that $100 i saved with the scat to put towards heads.
