JuiSSed
08-24-2003, 12:23 AM
i need a timing retard box to work with my MSD 6A and MSD window switch.. i need to pull out between 5-6 degrees for my system to work without detonation..
thanks
vinnie
thanks
vinnie
Best Timing Retard Box??JuiSSed 08-24-2003, 12:23 AM i need a timing retard box to work with my MSD 6A and MSD window switch.. i need to pull out between 5-6 degrees for my system to work without detonation.. thanks vinnie FastZonTNT 08-27-2003, 01:07 PM The TIMING TUNER box is awesome:bow: JuiSSed 08-27-2003, 01:09 PM Timing Tuner?? More info please!:) FastZonTNT 08-28-2003, 09:08 AM Do a search for it as TIMING TUNER. Its also a nitrous controller box all in one. It plugs into a few sensors and the crankcase. You can mount it beside your air box and easily adjust timing with turn of a knob. Heres what it doe... advances timing, retards timing when nitrous is activated, built in window switch, and also if you have a superchager it gradually takes timing out rather than all at one time. Loadre 08-28-2003, 03:59 PM Mallory's Hyfire VI (part #685) is QUITE good. Look it up on jegs. | ||
