steelheart
08-22-2003, 06:04 PM
instead of putting the micro switch on the throttle body can i wire it to the inside of the car and use it by hand to spray when i want to spray instead of spraying when the throttle wants to??
micro switch ?steelheart 08-22-2003, 06:04 PM instead of putting the micro switch on the throttle body can i wire it to the inside of the car and use it by hand to spray when i want to spray instead of spraying when the throttle wants to?? 95 Mystic TA 08-22-2003, 07:37 PM I went to check on my car at the local shop who is doing the install and I was extremely impressed with the way everything is hidden. They took and mounted my microswitch under the shifter plate so that when the button on th shifter is mashed in, it would spray when the system was on and at full throttle. Very good install in my opinion, couldn't even tell the bottle is on. I would take a pic but I won't have the car back until late tommorow. LPEdave 08-22-2003, 08:07 PM Originally posted by steelheart instead of putting the micro switch on the throttle body can i wire it to the inside of the car and use it by hand to spray when i want to spray instead of spraying when the throttle wants to?? You certainly can. Of course "the throttle" is your right foot :) Dave BBCAM 08-23-2003, 02:24 AM YOU need to keep in mind that you should ONLY spray at WOT anything other than WOT and you stand the chance of N20 build up in the manifold and that can be costly ....:eek: | ||
