Does anyone else have probs w/ their stock sway bar fitment w/ strange 12-bolt?
Old Aug 22, 2003 | 12:35 AM
1loudz's Avatar
it just seems like it too small and it digs into the aluminum cover on the rear end, which doesnt make it look too great! this cant be right! any input? do i need an aftermarket one to clear the 12-bolt housing?
thanks,
Ryan
Old Aug 22, 2003 | 12:54 AM
AL SS590 M6's Avatar
Moderator
On a Moser 12 bolt I installed for a friend the stock one worked just fine. We had to loosen all of the clamps and end links then rotate the bar to where it sat good. We tightened the clamps first then the end links.
Old Aug 22, 2003 | 12:56 AM
1loudz's Avatar
maybe i should try positioning it another way. it looks good when i tighten it up, but then as soon as the weight of the car is back down on it, it swings back up into the rear-end cover.
Old Aug 22, 2003 | 02:08 AM
Moderator
Well then put the jack stands under the axle so that the changes that you make are with the weight already on the axle.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
8T8IROC
Mar 26, 2015 09:02 PM
thenewkid
Nov 27, 2014 09:41 AM
