multi misfire/p300 code problem solved
Old Aug 21, 2003 | 09:30 PM
Bandit97's Avatar
I was getting the multi cylinder misfire code as has a lot of lt1 owners and did new plugs, wires, opti, and even new temp sensor, and turned out my problem was a blown egr and/or clogged fuel filter. changed those two things sunday night, and car is running like it did when i first got it 4 yrs ago. wohoo not saying that this is the problem for you other guys with the same code or misfire, but you might wannna check it. my egr sounded like a murraca and worked like a straw, (could blow through it easily) and the filter was pretty bad too. no probs since then and no ses light. Woot Woot!!!!
Old Aug 21, 2003 | 10:14 PM
Bandit97's Avatar
ttt for those that have this prob and have not fixed it yet, serioulsy try these things.
Old Aug 21, 2003 | 10:15 PM
doodad's Avatar
Were you throwing p0400 code for the EGR as well? And how bad was the misfire hurting you? Could you tell it was misfiring? Symptoms please as I am looking at something similar. thanks.
Old Aug 22, 2003 | 04:58 PM
Bandit97's Avatar
no i never threw an egr code, and hell yes i could FEEL and HEAR the misfire, my gas milage went from 305 miles a tank to just under 200 miles a tank, and the car ran like ****. It never once threw an egr code, only the p300 code. Like i said i did msd wires, ngk plugs, brand new opti and still no help, but after changing the fuel filter and the egr, which i did last sunday, my car has ran great, and no ses light since then either. it is worth the try to do both the filter and the egr since the filter is only like 10 bucks and the egr is 50 from autozone, vs new opti 200, new plugs and wires installed most places 400 for a total of at least 600 and if you let some shop do your opti then you are looking at even more. I did my own opti, but had a shop here in ft worth do the plugs and wires for 260. try it you never know, i had a lot of peeps say that it couldnt be my egr or filter that it had to be the pcm, but i did egr neways and that was the prob.
cody
Old Aug 22, 2003 | 05:11 PM
doodad's Avatar
Well I guess mine is the opti and the EGR not getting something it needs. That's OK, I will delete the EGR and replace the opti and see where we are. Thanks.
David Dorris
Jan 17, 2015 08:10 PM
HCz28
Jan 11, 2015 11:21 AM
Ari G
Dec 11, 2014 03:21 PM
SAR2K
Sep 1, 2002 10:49 AM
Darth Xed
12
Jun 27, 2002 07:46 PM
