Gear whine from 60-40mph only??
Old Aug 21, 2003 | 03:22 PM
JuiSSed's Avatar
i just recently installed Motive 3:73's in my 10 bolt.. i'm only getting gear whine on deceleration from 60-40mph.. nothing on acceleration or anything beloew 40mph.. i kept the factory Torsen with the gear swap.. is it that the gears need to be re-adjusted? or could it be the Torsen unit?
thanks
vinnie
Old Aug 21, 2003 | 10:28 PM
Got-LT1's Avatar
The gears MIGHT need to be ajusted. When I put in my 3.73s the first time, they only whined on decelration (but real bad). I went back in and found I was off on the pinion angle (i think it was this angle, did gears two years ago) by a few hundreths of an inch. use a dial indicator to check the angles. Hope that helps.
Old Aug 22, 2003 | 04:26 PM
JuiSSed's Avatar
thanks for the reply.. i'll give it a shot and re-check it..
thanks
vinnie
HarleyZ28
Oct 5, 2015 06:23 AM
CARiD
Apr 8, 2015 08:08 AM
737drivr
Feb 20, 2015 11:54 AM
ddr698
Jan 9, 2015 10:05 AM
Jessie4tin
Jan 7, 2015 08:53 AM
