AFTERMARKET CAMARO COMPUTOR
89 IROC DROP TOP
08-15-2002, 09:12 PM
DOES ANY COMPANY BUILD A COMPUTOR TO GO WITH THE MODS ON YOUR CAR ???? I CAN'T PASS ILL. EMISSIONS WITH A CAMARO THAT ALWAYS PASSED CALIFORNIA EMISSIONS !!! I REPLACED THE MAF & MAP 'CAUSE THAT'S THE CODES THAT CAME UP, BUT THEY'RE STILL THERE !!!! MEL
formula305tpi
08-17-2002, 05:15 PM
Even if you changed the faulty component the trouble code will still be in the computer. To clear it you have to disconnect your negative battery terminal for about a minute. Then the only code you will have are codes that are still in effect or new ones.
'92 Formula, 305 TPI
aklim
08-17-2002, 10:18 PM
What have you done to the car?
They have custom ERPOMS that work well. I highly recommend www.fasterproms.com (http://www.fasterproms.com) if that is what you want. However, without knowing what you did to the car, who can say what it is doing?
