StorminNorm
08-18-2003, 11:05 AM
I need to get in the door panel to inspect the window mechanism (the windows are crooked and wont go up staright on their own.
How do I get the window crank handle off?StorminNorm 08-18-2003, 11:05 AM I need to get in the door panel to inspect the window mechanism (the windows are crooked and wont go up staright on their own. jy211 08-18-2003, 11:29 AM There is a clip on the back of the handle. A skinny screw driver should be able to fit behind it and wedge the clip off. Then the handle should pull off.... StorminNorm 08-18-2003, 11:32 AM Originally posted by jy211 There is a clip on the back of the handle. A skinny screw driver should be able to fit behind it and wedge the clip off. Then the handle should pull off.... Thanks - I'll give it a shot. jg95z28 08-18-2003, 02:10 PM There's a special tool for removing window cranks. You should be able to pick one up at your local autoparts store. (Motormite, a.k.a. Help! carries one.) Its much easier than a screwdriver although that will also work. StorminNorm 08-18-2003, 02:13 PM Originally posted by jg95z28 There's a special tool for removing window cranks. You should be able to pick one up at your local autoparts store. (Motormite, a.k.a. Help! carries one.) Its much easier than a screwdriver although that will also work. Pep Boys here I come. Daweazel 08-18-2003, 07:03 PM that special tool is called a rag:D just wrap the rag behind the handle and turn it like your rolling down the window. The clip will come out with no problem. StorminNorm 08-19-2003, 10:07 AM Originally posted by Daweazel that special tool is called a rag:D just wrap the rag behind the handle and turn it like your rolling down the window. The clip will come out with no problem. That's even better. I havent had time to get out to an auto parts store. JEDCamino 08-19-2003, 11:52 AM Originally posted by Daweazel that special tool is called a rag:D just wrap the rag behind the handle and turn it like your rolling down the window. The clip will come out with no problem. I'll have to try that next time. Thanks! :D:thumb: | ||
