485 HP/ 11.2 Camaro FS!!!
Old Aug 18, 2003 | 09:36 AM
95TA8280's Avatar
It's a 76 body with a rebuilt engine from a 67. The specs are below:
-1967 327 30 over rebuilt 4500 miles ago
-Keith Black domed racing pistons 12.1 CR
-Forged steel small journal crank
-Moroso high volume oil pump
-2-bolt block
-783 cfm double pumper with 4 corner idle and fast jet change
-Weiand single plane intake 2500-6500
-Comp Cams xtreme energy 284
-385 aluminum heads
-B&M manual shift kit
-B&M "slap shift" shifter.
-3000 B&M stall convertor
-8.5" 10 bolt with strange 3.73 gears limited slip.
-Full fiberglass front end including left-right fenders and inner fenders with 4.5 inch Harwood fiber hood
-American racing 15x8.5 front 245/50/15 15x9 265/50/15 rear
-Air shocks in rear
-Hotchkis springs and KYB shocks in front with new bushings and lower ball joints
-Heddman headers 1 3/4 primaries to 3 inch collector
-20 gallon fuel cell in the trunk with full braided stainless steel fuel lines
-No Heater or A/C in order to lose some weight. Car has a new alt, rims and tires and battery.
-Radiator from an 80s model Monte Carlo, assuring the car will not run at a temperature of higher than 180 degrees.
Flaws: Car is a popcorn machine. The front two fendors need to be aligned so the whole front end will sit right. Front passenger fendor has a crack in it so it needs some fiberglass repair stuff, which is like $10. Rust on the rockers and starting on the shell, but it is not bad. New rockers and some rust away stuff will fix all that up. Yo ushoudl get new doors, which run about $150 each. Interior has rips and shoudl be replaced. Car needs to be painted, and it was sitting for a year it has faded. However, new (black)carpet was put in.
This is PERFECT for someone to restore over the winter and run a mint looking car for next season. Once the front fendors are fixed, you can easily take it to the track and pull the 11.2 that the last owner ran. On a 150 shot, he ran a 10.5.
Make me an offer, I'm looking to get rid of 3 cars and get an LS1
Old Aug 18, 2003 | 09:01 PM
95TA8280's Avatar
Doesn't somone wanna throw in a 150-200 shot in a car and do a 1/4 mile in the low 10s?
Old Aug 19, 2003 | 10:32 AM
95TA8280's Avatar
I'm looking for ABOUT 4K for this......I need money for an LS1!
Old Aug 19, 2003 | 10:38 AM
az94z28's Avatar
any pictures? I might be interested
if you have some email em to me @ jsbollingeraz@aol.com
thnx
Old Aug 21, 2003 | 11:32 AM
95TA8280's Avatar
TTT!!!
4K and you're at low 11s!!!!
Old Aug 22, 2003 | 10:46 AM
95TA8280's Avatar
TTT.....anyone? anyone?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
NewsBot
Jan 11, 2015 06:10 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
