thewinner
08-16-2003, 07:57 PM
Well, whats the best way to drop the CR for a FI application? Through the pistons or the heads?
Currently i have a forged setup in my n/a 383 and want some boost. Is the best way to go about this through the piston dish or the combustion chambers?
I currently have ~55 cc chambers i believe and -15 cc dished pistons for a CR of about 10.8
I plan to get a set of AFR heads, and by using a CR calculator, it looks like i wont be able to get a big enough drop by the heads only.
A 74cc head and a 26 cc dish piston will net a 8.15 CR if i am right. and a 74 cc head with my current 15 cc dished pistons will only take me to 8.95
So, simply put, I will most likely be getting pistons specifically for boost apps. But where should I plan to take out the most CR from? What will give the best characteristics? I suppose i can always get a Cometic head gasket in any thickness to drop it some right?
What is the optimal combo here for a CR around 8?
