Z95m6
08-15-2003, 02:02 AM
I need to build a reluctor ring to go on the driveshaft yoke of my Z so i can have ABS with my 8.8. I need to find a yoke out of a junk car so i can have a machine shop make me a gear to go over it? Will one out of a V6 car work? or a LS1? I would think all 4th gens would be the same outside diameter. The only diff would be the splines on the inside correct?
OneFlyn95z28
08-16-2003, 01:06 AM
Most 4th Gen yolks are the same. Not sure on the two piece 3.4 shaft but I think it is also.
I would go get a new one(like $50) and have it machined. they do not have the harmonic ring on them and will give more room to install your ring ;)
Why not try to piggy back off the Speedo Sensor?
Good luck!
Z95m6
08-16-2003, 01:37 AM
i checked on getting a new yoke and dealers want 180 for one. I don't know where else to get one. I called the local Fbody salvage yard and he only had one for a automatic and i am not sure if that will work.
OneFlyn95z28
08-16-2003, 09:52 AM
Give Arron Spitzer a call at Randy's Ring and Pinion.
You can find the number in any car mag ;)
Arron can be found 1.800.347.1178 #5579
