BADAZZ_Z28
07-24-2002, 02:25 PM
How much trouble would it be to swap my 4bbl 305 out for a 350 from a 94 caprice? has anyone done this? is it the same 350 as a basic 350 tpi?
Different 305 to 350 questionBADAZZ_Z28 07-24-2002, 02:25 PM How much trouble would it be to swap my 4bbl 305 out for a 350 from a 94 caprice? has anyone done this? is it the same 350 as a basic 350 tpi? robvas 07-24-2002, 02:44 PM Piece of cake swap. BADAZZ_Z28 07-24-2002, 03:00 PM well what will i need and around how much will it cost? 86IrocCamaro 07-24-2002, 04:01 PM u dont need n e thing but some wrenches and a lil bit of elbow greese. some bigger injectors would be nice, that 350 isnt gonna like those 305 injectors ------------------ 86 Iroc Z28 350 4 bolt main .60 over 11.5:1 CR 280 Comp Cam 2.02 P&P Heads Eldebrock Intake Holley 600 carb Holley FreFlow Air Filter 4:11 Gears Th350 Transmission 86IrocCamaro 07-24-2002, 04:03 PM my bad u said carb engine, should be just fine then ------------------ 86 Iroc Z28 350 4 bolt main .60 over 11.5:1 CR 280 Comp Cam 2.02 P&P Heads Eldebrock Intake Holley 600 carb Holley FreFlow Air Filter 4:11 Gears Th350 Transmission BADAZZ_Z28 07-24-2002, 09:32 PM I have a carb and im switching over to a tpi because im having trouble locating a carbed 350. So pretty much i need to know how to switch from carbed to tpi while switching from 305 to 350. cmon i know someone has done this before.... roc87 07-25-2002, 12:28 PM Get a painless wiring kit, It'll be much easier than trying to use the stock harness. You'll have to either put in the LT1 fuel pump, or put one in line. Not too sure about motor mounts... ------------------ "NOV8Z28" - '87 20th Anniversary Iroc-Z Convertible, leather, 1200 watt stereo, Spohn torque arm/tranny mount,6 pt. roll bar, 5 pt. harness, 4" cowl hood, '92 Z28 Rear spoiler, 3.8 SFI Turbo/200R4 from '86 Buick T-Type, 42# (009) Injectors, Custom chip, RJC power plate, Dutweiler neck IC, Adj. FP Reg., 14" K&N, Walbro 340 FP, 3" exhaust with gutted crossflow flowmaster, 17" Boyds, 4.11 rear end. Http://CamaroZ28.cardomain.com/id/roc87 | ||
