Fuel Injectors !
shwine617
08-14-2003, 03:06 PM
hi,
I made a post before about this, like i said before I can't find out what size injectors they are, but this time I have the number off one of the injectors, the number is 9199 and the injector is a greenish color.
thanks
shwine617
08-14-2003, 03:57 PM
i found more numbers on the injector , they are 17086542
so that make it 9199 17086542
thanks
aklim
08-15-2003, 12:35 AM
According to http://www.pic-fleet.com/theme/frameset/top.cfm?referringurl=http%3A%2F%2Fwww%2Egoogle%2Ec om%2Fsearch%3Fhl%3Den%26ie%3DUTF%2D8%26oe%3DUTF%2D 8%26q%3Dgm%2Bpart%2Bnumber
They are for the 5.0L. That begs the question. What is the 8th digit of your vin?
Geezer powered
08-15-2003, 12:37 AM
sorry didn't see this post:( Aklim I think the car has a 350 swap.
shwine617
08-15-2003, 12:04 PM
thanks AKLIM !!
yes, mine are 19lb injectors, which will explain the fuel starving to my 350, I am probably going to get some 24lb instead of the stock 22.
thanks again everyone!!
aklim
08-15-2003, 10:20 PM
Now you are going the other way. You will run rich. You might have to go with someone to custom burn your EPROM if you do. That is unless you are MAF and it might adjust itself.
shwine617
08-16-2003, 11:46 AM
yea i know i am gonna run rich, but just for a little while until i get money to get my eprom burned, for now i am getting the adjustable fuel regulator and i am goin to turn the pressure down a bit.
aklim
08-16-2003, 12:05 PM
Not sure you can turn it below stock pressure tho. Who is doing your EPROM and what do they think?
aklim
shwine617
08-16-2003, 12:13 PM
I am not sure who is doing it for me yet, i have to find somewhere in NJ
