SteveLT1
08-14-2003, 12:00 PM
I picked up this cam on advice from comp cams in reguards to this setup 6 speed 3.73 gears 355 lt1 with srp pistons 10.4 to 1 compression,asm 1 3/4 headers, 1.6 roller rockers,3angle valve job on stock lt1 heads,ati p600b 8 psi supercharger with 2 core intercooler,random technology dual cat y pipe,flowmaster cat back,24lb bosch injectors,scat 9000 series crank,4340 h beam rods. Was the cam they suggested for me too mild for the application? At this point is it worth me..going to a better cam will the difference be worth it etc... heres some info on the comp cams cam 07-305-08
Comp Cams "305" LT1 Camshaft, 220 / 230, .510 / .510 114 LSA, More aggressive with good street drivability and decent vacuum. Good midrange power.
Any input is appreciated thanks
Steve
Steve
