SSR Engine Question
Old Aug 13, 2003 | 10:07 PM
Z28x's Avatar
SSR Engine Question
Can someone that has some inside knowledge at GM tell me why GM went with the 300HP 5.3L in the SSR instead of the LS1 or 345HP 6.0L?
THe cost of manufactoring a 5.3,5.7, or 6.0L V8 is almost the same and GM makes an A4 that can handle the power of each.
cost of the truck can't be an issue either, with a base price of $42K I don't think another $500 to $1,000 would have stoped anyone from buying one.
Old Aug 13, 2003 | 10:16 PM
Jason E's Avatar
Could it be a severe lack of BRAINS???? Thats all I can come up with...
Old Aug 13, 2003 | 10:22 PM
99blackSS's Avatar
It probably has something to do with emissions. The CAGS on the M6 LS1s was done for emissions. Plus the bigger engine would probably increase the gas guzler tax. Won't 300hp make the SSR somewhat quick, or is it heavier then it looks?
Old Aug 13, 2003 | 10:31 PM
84 Z/28 Camaro's Avatar
the SSR is a BEAST...I dont have the numbers in front of me, but I do recall it weighing at LEAST five thousand pounds, thanks to the retractable hardtop..
Old Aug 13, 2003 | 10:37 PM
Z28x's Avatar
I doubt the emissions thing, THe Camaro had an LS1 and A4 and the silverado SS has the 345HP 6.0L and an A4.
THe curb weight is 4764Lbs.
C&D clocked it at 7.0 sec. 0-60, 15.4 in the 1/4mi.
Silverado SS stats for comparison:
curb weight is 5240Lbs.
0-60 in 6.3 sec.
1/4mi. in 14.8 sec.
Old Aug 14, 2003 | 06:43 AM
Eric Bryant's Avatar
My guess would be fuel economy (that, and not emissions, is the reason for the existance of CAGS). But, the SSR is such low-volume that I can't imagine it impacts GM's light-truck CAFE ratings by any significant amount, so it would have been great to see the LQ9 6.0 L in it. Or throw the LS1 in it - for $40K+, an aluminum block would have been nice.
Old Aug 14, 2003 | 07:04 AM
SNEAKY NEIL's Avatar
Isn't the 5.3 in the SSR all aluminum?
I am guessing that GM put the 5.3 in there initially and will increase this over time to keep it fresh.
Old Aug 14, 2003 | 08:02 AM
BAD APPLE's Avatar
There were several reasons why it couldn't happen. Production numbers on the LQ9 are limited, and they may not have had the ability to change that.
The SSR DOES have an aluminum block. This 5.3 (the LM4) is the same one used this year in the GMT360/370. The GMT800's continue with the iron-block LM7.
While the exterior dimensions of all the vortecs are about the same (therefore making it seem like any of them should drop in and go) the SSR's front end provided some very challenging issues with airflow/cooling that had to be resolved.
Just wait until 2005
Old Aug 14, 2003 | 08:21 AM
formula79's Avatar
The SSR is built on a Trailblazer EXT platform. The EXT has a5.3L option from the beginning, so it was probaly much easier. Ford was able to skip crash testing with the Thunderbird because it was so similar to the LS...same engines and all. The SSR possibly fell in this catagory. Even though the 5.3 and 6.0 are the same size I believe different dispacements mean you have to do crash testing over. Also I would imagine alot of the computers and such carry straight over from the EXT, but would have to be totally replaced if they went to a 6.0L.
Old Aug 14, 2003 | 08:54 AM
Ah, didn't realize that was already an Al block in that application. There goes my brilliant weight-reduction idea
And yet more good info - that's a very valid reason to cut back on the HP (although I know damn well that this problem will probably be overcome by some company like Lingenfelter, using an inexpensive solution that probably wasn't implimented by GM because it would have hurt their gazillion-dollar profit margin).
They're going to get 400 HP and have the price cut down to $25K? Oh, I guess not. How 'bout enough power to at least keep up with a SRT-4 that's only half the cost?
Old Aug 14, 2003 | 11:02 AM
BAD APPLE's Avatar
Yeah, I wouldn't be surprised to see an SSR or 2 lined up at LPE's doorstep this fall. They make some very innovative, very desireable packages. However, these blown/stroked vehicles would not pass most of the cooling tests their production counterparts do. Not to say they aren't fine for 95% of the customers, just don't tow your boat up a mountain in Death Valley at 120deg!
They're going to get 400 HP and have the price cut down to $25K? Oh, I guess not. How 'bout enough power to at least keep up with a SRT-4 that's only half the cost? [/B][/QUOTE]
The power yes, the price we can only hope remains the same. This "shared" engine will debut in about 3 products the same year.
Old Aug 14, 2003 | 11:27 AM
IREngineer's Avatar
The power yes, the price we can only hope remains the same. This "shared" engine will debut in about 3 products the same year. [/B]
Hmm, LS2? That would leave base vette. CTSv, and SSR. Kind of makes sense. Makes this niche vehicle a lot more appropriately(sp) priced in the LOW $40k's.
Old Aug 14, 2003 | 11:37 AM
jg95z28's Avatar
0-60 in 6.3 sec.
1/4mi. in 14.8 sec.
Actually it was 0-60 in 7.7 sec.
What a pig.
It sure "looks" cool though.
Keep in mind its an aluminum block 5.3, so it isn't quite the same as the std truck motor.
Old Aug 14, 2003 | 01:09 PM
95 Z/28 LT1's Avatar
Super Moderator
You forgot the GTO. Hopefully it'll get the LS2 and the CTSv can stick with the LS6/Z06 engine.
Old Aug 14, 2003 | 01:16 PM
Super Moderator
Any chance of the SSR becoming GM's Lightning fighter?
