camaro9402
08-13-2003, 05:12 PM
is there anything i can do to my 2.8 to make it more peppy other than put a new engine in it can someone help thanks
2.8 ?camaro9402 08-13-2003, 05:12 PM is there anything i can do to my 2.8 to make it more peppy other than put a new engine in it can someone help thanks kevin 2.8 08-13-2003, 06:00 PM you can, but i wouldnt. its not a very good $ to benifiet . i have the 2.8 fi id do just free stuff like exhaust cut out and gut cat, other than that you could spend the same $ on another camaro. the fastest 2.8 ive heard on this board was 15.9sec 1/4 forget who it was but he said /quote Rebuilt Tranny with Shift Kit at firmest level, Corvette Servo 2000RPM Stall MSD Coil Accel Wires No Spare Tire No Floor Mats No car audio stuff like HU or box Hurst Dual Gate Shifter set in D not OD NO TB Coolant lines NO MAF Screen Ported upper plenum (home done) Custom Intake I made with PVC and Conical Fastr Chip by Ed Wright Stage 2 Synthetic Oil Stock AC Delco Plugs changed yearly Rear tires at 21PSI Front at 42PSI Dynomax Cat Back Exhaust Catco High Flow Conv you should also check out this page, some guy twin turboed a 2.8 gm motor in a 500 datsun doesnt have any #'s but im guessing over 300hp http://www.bryanf.com/mycars/510V6.htm also check out some 2.8 - 3.4 swap threads, you dont need much more than the block to do that swap, you can use almost all the 2.8 motors hardware & acc. -kev | ||
