amc91z
05-03-2002, 03:48 PM
Any info on the swap will be really helpful. I'll be swaping the LS1 and 6-speed http://web.camaross.com/bb/smile.giffor my 305 TPI and auto http://web.camaross.com/bb/frown.gif. THANKS!!!
LS1 into 3rd Gen????amc91z 05-03-2002, 03:48 PM Any info on the swap will be really helpful. I'll be swaping the LS1 and 6-speed http://web.camaross.com/bb/smile.giffor my 305 TPI and auto http://web.camaross.com/bb/frown.gif. THANKS!!! My90Iroc 05-03-2002, 05:59 PM Check out www.thirdgen.org (http://www.thirdgen.org) there's some info over there either in the tech. articles or in the forums. There's also a couple of guys out there who've done this and documented it on their websites, but unfortunately I don't know the sites. I can give you some basic ideas about what you're getting into. You'll need to make custom motor mounts, you'll need to whole wiring harness and computer, you'll need the fuel pump or one designed for the LS1, and you'll need the clutch hydralics from the 4th gen. I've heard that the wiring harness is a real pain to match up to your can, and if painless wiring makes one for this application and you can afford it, I'd go that way. You need the fuel pump because there's no fuel pressure regulator on the LS1, so it increases/decreases the fuel pump output as it needs more/less pressure. The 3rd gen clutch hydraulics don't work with the 4th gen T-56's so that's why you need to 4th gen parts, and you'll also need a signal converter to make your speedo work correctly. I think everything I've said here is accurate, or very close to it, but this is a very basic introduction. Definitely do your research. Good luck and keep us up to date. ------------------ '89 Camaro RS 6 cyl. auto (Sold) '90 Iroc TPI 305 5spd posi bought on 9/22/00 :) B&M ripper, hopefully more to come, if I rob a bank or something http://www.geocities.com/irocnroll90/ www.wreckyourneck.com (http://www.wreckyourneck.com) for info about the radio show I co-host kandied91z 05-03-2002, 06:59 PM very, very costly conversion for what you get....but cool to see! good luck with it! 91RS5speed 05-03-2002, 09:57 PM Here is a sight of a guy who did it. http://www.geocities.com/MotorCity/Downs/8158/ls1.html ------------------ 91 RS Camaro (http://bitchincamaro.no-ip.com) 5-speed black w/t-tops 305 TBI now TPI MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 180 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace Jacobs454 07-22-2002, 12:16 AM I've asked around locally about that same installation and here's what I got from it. To install an L98, LT1, or LS1 5.7 you are looking at a combination of simple and difficult dynamics. The engine/tranny swap itself is not that big a deal. You will need to enquire with a dealer on wether or not the transmission mount will mount up to the T-56, but the motor mounts should be fine. The big deal is wiring. Since the 3rd and 4th generation Camaros had different wiring, that'll be your biggest feat. I know a guy that buys exprired and totalled state vehicles (police cruisers, etc.) and does engine/transmission swaps with them. He can take a '95 Caprice (LT1, 285HP) and install it in a 3rd gen F-body with no sweat. If the LT1 will work, the LS1 shouldn't be a problem, just more expensive to aqcuire. Hopew this helps! kandied91z 07-22-2002, 12:55 AM it's alot more than an lt1......do your research before jumping into it with both feet. beyond the average know how for the engine and trans there is the custom motor mounts, wire harness installation, new computer, and adapting the guages.......there are many other things but these are the biggest concerns. save your money and build a small block, unless your getting a deal or have the money to make the application really work it isn't worth the time. | ||
