Engine Temperature???
Old Aug 8, 2003 | 02:13 PM
Striker27's Avatar
Well my car has a 160 degree thermostat and I just put in a new water pump. The car likes to run about the middle of the gauge with the air on or just alittle a past that. Is this normal is their any kind of mod I could do to have the fans come on sooner? Also is it possible that the thermostat may be bad it has been theuir for 5 yrs.
THANX
Old Aug 8, 2003 | 02:20 PM
predator's Avatar
you have probably got air still in the system takes a while to get it all out use the bleeder valves with the heater on high
Old Aug 8, 2003 | 02:23 PM
DjArcadian's Avatar
Bleed the air from your system. Very easy to do. Your owners manual will tell you how to do it. You can get your PCM reprogrammed so the fans trigger at a lower temp but if there is air in your system it won't help much.
Checkout Shoebox's website at http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html for instructions on how to bleed your car.
Old Aug 8, 2003 | 03:18 PM
Striker27's Avatar
Well I bleed the system and with the fans on high the temp is coming down to about half way between the first hash mark and the middle of the gauge or 100 on my Cdn car with it sitting in park. Is this in the normal range for the car.
THANX
Old Aug 8, 2003 | 04:03 PM
ZaneO's Avatar
I would say try bleeding it first, and if that doesn't work, then you can buy a new tstat.
Old Aug 8, 2003 | 04:14 PM
ONELOUDKAR's Avatar
bleed the system..... get your fans to come on soone by getting some sort of tune... reaplce thermostat if neither of these work.
let me ask this to whomever, if a 160 thermo is put it, doesnt it have to be be set in the computer for it to be effective?
Old Aug 8, 2003 | 04:16 PM
lbrowne's Avatar
my car sits just past 100 when idling in traffic too, once i start moving it goes down. but fans don't come on, at least i can't ehar them.
i don't use my air conditioning. I've drained my system and got the air out of it as well, same deal.
i had another post on the go here but no one told me at what point on that guage is the fan suppose to turn on.
Old Aug 8, 2003 | 04:50 PM
TobyZ28's Avatar
With a 160 thermo and stock programming the fans will come on at the same temperatures. So when in traffic or idling.. the engine temp will be the same as before. When your on the highway the thermo will open sooner and allow your engine to be cooler than with the stock thermostat.
So the answer is:
Yes it has to be set in the computer for it to be effective when not driving steadily.
Not it doesn't have to be set in the computer for it to be effective when your driving on the highway.
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
Rich_z28
May 6, 2003 08:38 PM
