Backfire
Old Aug 7, 2003 | 11:53 PM
Sterlingsxe's Avatar
Backfire
Guys whenever i floor my car. It reves and it like wants to go into the next gear but wont until i let off the gas and then slam it back down. What is the cuase of this low tranny fluid. I filled it up a few months back it seem to work. Also when i floor it sumtimes i have multiple backfire. Do i just need some new plugs? And if i do n e suggestions
Old Aug 8, 2003 | 05:41 AM
superadobo808's Avatar
im not sure
im not sure exactly what is wrong with your car, but i had something similar to that happen to me. Soon after it started to do that, the trans seal broke and the new pump in the trans died. it would rev up to the red line and just bounce there, till it felt like shifting. If your car is only reving up to like 4500rpm and not reaching the redline, you should try fuel injection cleaner cuz its not your trans, your car wont shift untill the redline at full throtle. Hope this kinda helps
Old Aug 8, 2003 | 05:58 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Transmission problem
i think you need a rebuild... check for the obvious symptoms... burnt fluid.. etc
Old Aug 9, 2003 | 12:14 PM
nope no burnt fluid. Seals are still good. Everything fine. Except only sometimes when i floor it. It doesnt do it that oftens. But mayve i just have a trans leak somewhere. I will look and maybe my plugs are dirty people dont liek to change them its a bitch
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Dzmaro
Jun 19, 2015 11:38 AM
Chet1185
May 10, 2015 09:24 AM
