CaysE
06-28-2002, 09:55 PM
OK, here's the story:
In the process of replacing the engine oil pressure switch, I had to remove the distibutor (or just lift it up a bit, but removing seemed easier at the time). Two problems: I began lifting out the dist (about half an inch), then placed it back in, remembering to mark everything. Though I marked the rotor to the housing, I forgot to mark the housing to the block. You can guess the rest of the problem from here, I bet: I wasn't able to accurately place the distributor back onto the block. Fortunately, it seems that there is a guide plate inside the bottom of the distributor gear, so you can really only place the distributor back in the engine at two points: the correct location and 180 degrees opposite. I took my best shot as memory served me and tried placing it in, and it slid in smoothly. Here's problem number 2:
Though the rotor now seems to be in the correct spot and the markings between the rotor and housing line up, the housing seems off from where it originally was on the block. I fitted the dist cap back on the housing, and what led me to think that the housing wasn't on right was that the ignition wire retainer (with four wires still attached) wouldn't fit quite right. So here are my questions:
1.) I really doubt that this could've happened, but I'll ask anyway... is it possible that the engine could have cranked just a bit while removing the dist, thus throwing off my marks?
2.) The rotor itself seems to be in the same position visually as it did when I removed it. Is there any way to tell if the housing is in the correct position by a marking or something that was already there? It seems haphazard for Chevy not to have put some kind of indication that the housing is seated properly.
3.) If not, is it safe to rotate the housing to where I believe it originally was? It's not off by much, maybe 5 degrees or so; I can align it with the comfortable position that the ignition wire retainer would be placed on the cap. I don't think it would rotate so much that the rotor would be firing different cylinders (if the distibutor gear isn't lined up correctly), but it WOULD be off if I'm wrong.
Sorry for the long post; I just really need some help with this so I don't destroy a perfectly good engine. =\
1984 Camaro Coupe LG4 V8 (5.0L 305ci) 700R4 Transmission K&N Filtercharger
