How or what to use to clean top of pistons?
Old Aug 7, 2003 | 07:41 PM
Mr.Whitey's Avatar
I have the heads off and I am planning on putting the heads back on this weekend. The top of the pistons seem to have a build up of carbon. What can I use or do to remove it? It's not like a quater inch of build up but there are some thick areas.
Thanks!
Old Aug 7, 2003 | 07:55 PM
Robert95z's Avatar
My friend used (i think it was) o'reilly brake cleaner to clean off his valves and heads on his 498ci bbc
Old Aug 7, 2003 | 08:48 PM
QCKZ28's Avatar
i used brake cleaner with a rag and just scrubbed away.
jesse
Old Aug 8, 2003 | 03:46 AM
Compstall's Avatar
I've used a razorblade in the past. Just make sure you scrape towards the center of the piston, then take a vacuum and suck up the gunk. After that, you can use brake cleaner or anything similar on a rag and rub the rest off.
pimpss96
Feb 12, 2015 01:28 PM
1963SS
Feb 6, 2015 10:05 AM
squarehead
Nov 21, 2014 08:02 PM
