Front tires rubbing!
BadIroc
06-10-2002, 01:10 AM
everytime i have my wheel turned all the way the font tires like to rub in the wheel wells. I have the stock tire size on it 245/50/16's and the wheel well is on there fine not hanging or anything. It will do it on both sides not all the time only on sharp turn turned all the way. Could it be somthing in my front end? dont know anymore...thanks.
1988 Camaro IROCZ "MIDNIGHT CRUIZERS"
305 ci Tuned Port 700R4
3"Exhaust/Flowmaster 80 series muffler/Dynomax high flow cat/CutOut
hypertech chip/k&n filers, cut MAF screen gutted air box
"Theres no replacement for displacement"
My Iroc web page....
www.geocities.com/bobfitz82/index.html (http://www.geocities.com/bobfitz82/index.html)
BadIroc
06-10-2002, 06:59 PM
ttt
1fastformula
06-10-2002, 07:41 PM
One word.....Offset!!!! The rim offsets are different from front to back. I once rotated my tires front to back and I had the same rubbing!!! Have you rotated your tires recently or did you buy the car this way.....Bring it in to your tire man and have him pull the front tire off and look at the tie rod (I think). You should have rubbing where the rim is too wide.
I hope this helps you
Later
1989 Formula 350
K&N air filter, air foil, TB Bypass, AFPR (set at 45 psi), A.I.R. yanked out, Accel 8mm wires, Fireball external coil, Pulley (just the crank), gutted MAF, corvette servo, Hooker super comp. shorties, 3" exhaust all the way back, No cats, Flowmaster 40 series muffler (one in one out turned down)---Developed a bad habit....bottle related!!!!75 Shot of Nitrous
http://www.theformulasource.com/ownerslist/detail.php?siteid=144
So they made him get rid of it...For decency ya know....But it came back the next day...
My webpage:www.cardomain.com/id/1fastformula (http://www.cardomain.com/id/1fastformula)
BadIroc
06-11-2002, 02:43 AM
I know exactly what yo are talking about too because my rims are the offset ones and each say front or rear on them but all of them are were they should be so that can't be it. It actually seems like my left front tire sticks further back more towards the rocker panel. More on he left tire side then the right one but the right one seems a little bit off too. Any other ideas of what it could be?
BadIroc
06-11-2002, 06:44 PM
ttt
