head gasket??
ws6gta
06-09-2002, 09:41 PM
i have an 89 gta 350 l98 tpi.the car has some water coming out of the exhaust on start up until it warms up(more than the usual condensation)and it has almost a miss like sound out of the exhaust at idle.i have a few bubbles coming up in the radiator every 20-30 seconds.does this sound like a head gasket?is there anything special i need to know when pulling the haeds or any tricks to save me some time?any help would be excellent
thanks
Roger
angel71rs
06-09-2002, 10:15 PM
Yeah, that sounds like a head gasket. See which cylinder has a wet plug, or do a compression test to isolate the offending gasket.
GMTech
06-09-2002, 10:27 PM
Definatly sounds like a head gasket. Pull your plugs out. If it is burning coolant like you said, there should be deposits on the plug from the offending cylinder.
Webmaster:SETHIRDGEN (http://sethirdgen.org)
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
