Autocross and Road Racing Technique There is more to life than a straight line
Suspension Prob?Somebody help me out
Old Aug 2, 2003 | 12:36 AM
Zach94's Avatar
I have an Eibach Pro Kit with stock everything else suspension wise. I know very little about suspension, but I have a problem with wheel hop and I want to fix it. If someone could explain to me how to fix it and what I would need I would be very appreciative. By the way I have a V6 if that matters. Somebody Help!
Old Aug 2, 2003 | 04:17 PM
jd13's Avatar
Lower control arm relocation brackets. They will make your lower control arms parallel with the ground again. Right now they are at an angle creating your wheel hop.
Also, when you lowered your car you really should have gotten an adjustable panhard rod. When the car was lowered, the whole rear end more than likely shifted half an inch to an inch in one direction or the other. This will recenter your rear end.
Old Aug 3, 2003 | 04:27 AM
ChewyChevy's Avatar
The above two should definately fix your problems.
I would also suggest eventually upgrading your shocks as well. This should help improve handling performance as well.
Alex
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
