Glimmer
07-30-2003, 01:39 PM
http://hem.bredband.net/b123938/avgas/01.jpg
http://hem.bredband.net/b123938/avgas/02.jpg
http://hem.bredband.net/b123938/avgas/03.jpg
http://hem.bredband.net/b123938/avgas/04.jpg
http://hem.bredband.net/b123938/avgas/05.jpg
http://hem.bredband.net/b123938/avgas/06.jpg
Iīm so fed up with the company who did this. They say itīs impossible to make it better. but I whent to another company and saw the system that they made, and theyīre SMOOTH all the way.
How much would this affect my setup?
TunedPort 335
07-30-2003, 01:43 PM
Very little I beleive.
Install a cutout and call it a day! :cool:
dewey316
07-30-2003, 01:44 PM
the ones you saw that are smooth are mandrel bent tubing, very few local shops ca do mandrel bending. there is alot of debate as to how much it effects performance, as the flow will go to the outside radius of the bend. if you want a mandrel bent system, you best bet is to buy a cat-back system from a major company, ie, flowmaster, hooker, dynomax, borla, ect.
Glimmer
07-30-2003, 02:02 PM
Both of them use mandrel bending, but the machines differ alot (Iīve seen both of the machineīs). Itīs more expensive in Sweden with a cat-back from the major companies.
The company with the good bending are using stainless, and the other oneīs using standard steel.
dewey316
07-31-2003, 08:14 AM
the pictures you attached are not mandrel bent.
Glimmer
07-31-2003, 09:54 AM
Uhm, Iīm sorry. I checked that out, and the system on the picture is "pressed" (donīt know the english word).
The other system that I wanīt is true mandrel, that I know now.
The price difference between the systems is $160. Too bad I didnīt know that before. I choose this company because itīs the only one in my town.
dewey316
07-31-2003, 12:52 PM
what size is the tubing you had it done with? like i said there is alot of debate as too how much madrel bending helps, since the flow is on the outside radius of the bend, i would be more concered with the OD of the tubing used.
Glimmer
07-31-2003, 06:14 PM
This is 3" from the catalyst and a Terminator muffler with single outlet.
Zepher
07-31-2003, 06:39 PM
That is a crush bend. A lot of people will use a larger pipe to give the same flow as a mandrel bent pipe.
Example, let's say you wanted to 2.5" mandrel bent pipe, you'd go with 2.75" crush bent to get similiar flow.
Glimmer
08-01-2003, 12:46 AM
Then it DO make a difference? They canīt fit larger than 3" in the machine.
Zepher
08-01-2003, 01:25 AM
It does make a difference to an extent.
You have to take into consideration how much air your car is getting versus the amount of exhaust gases leaving.
A big exhaust on a restricted engine won't have much affect versus a smaller exhaust.
