NOS system vs. Supercharger
Z28sTunner
09-04-2002, 07:49 PM
Admittedly, I am fairly novice when it comes to performance car tuning. I was weighing the pros and cons of installing either a NOS system or a supercharger on my car. WHich system is more reliable and can last with high performance results
2002 Z28 Navy BLue MettaLLic
A4
160 degree Hypertech Thermostat
Granatelli MAF
Granatelli Cold Air Lid
K&N Filter
SLP Ram Air Kit
Hypertech Power Programming III
FLowmaster 40series Muffler
Borla Polished Tips
30% sport tints, Plasma Bulbs
96SFLZ
09-04-2002, 08:42 PM
Well, the stock CR is 10.1:1 so IMO running anymore than 6psi of boost is asking for it. Even with only 6psi, you're still taking a chance. Nitrous works better with high compression so I personally think a 75-125 shot would be a better choice than boost. Of course, if you don't mind spending a little more $$ on a rebuild then I'd definitely go with the blower.
Aaron
Black '96 Z28 *sold*
¼- 12.97@107.2
SSM '02 Z28
Pro 5.0, FRA, MTI lid
¼- 13.21@108.2
smallwood
09-04-2002, 08:45 PM
Nitrous is alot cheaper for the same amount of power, but a charger is always there when you want that good feeling you get when you punch it, with no bottles to refill.
Little red light on the highway; big green light on the speedway, hey,hey, hey!
2002 Formula, GMMG cat back /1983 Z28-sold :(
Drew778/94Z
09-04-2002, 09:05 PM
I'd go Nitrous, cheaper and safer.
2002 SS #3442 Navy blue metallic A4 160 T-stat/TB by-pass/SLP fan swich/DMS SFC's/Direct-Flo Lid/Holley Filter/FTRA/LS-6 MAF/Magna Flow Cat-Back/SLP Y-pipe/
(Very first run stock with 750 miles)
60ft 2.162 1/8 8.782@83.48 1/4 13.553@102.93
Best for now:
60ft 1.847 1/8 8.329 @ 84.72 1/4 13.014 @ 105.13
nikkev
09-05-2002, 12:42 AM
I'd go nitrous.The only time you'll use it is the track.We already have too many ponies for the street as it is http://web.camaross.com/bb/eek.gif http://web.camaross.com/bb/biggrin.gif
Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics (http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t)
Camaro/Firebird Birthday Bash (http://www.corvettemuseum.com/registration/f-body/agenda.shtml)
smallwood
09-05-2002, 12:48 AM
NEVER to many ponies for the street!
The purple stuff will really make it go, at least once.
Freak
09-05-2002, 01:33 AM
given a chioce (money no object) I would go with a supercharger (actulay Id go turbo, but that wasnt one of your choices)
the reason is simple, its always there. and I dont mean only when you HAMMER the vertical pedal on the right, at speeds above where the boost starts (usualy around 2000 RPM for a centrifugal blower) you will have that added power. this is useful on the street. Passing on the highway for example, you would have a little added power. unlike nitrous which should only be used at WOT and above 3000 RPM (minimum on these cars IMO) if you dont follow these guidelines with Nitrous, then you could end up with a very expensive paperweight.
EDIT: oh, 2 other reasons.
You dont hve to fill it ever
unless you have a convertable, the only out of the way place ot put it is either the spare tire comparment or int he rear hatch wehre the t tops go. I refuse to leave my spare at home, and dont wnat to give up my t top storage space (otherwise I wouldnt have gotten t tops)
[This message has been edited by Freak (edited September 05, 2002).]
