etslbrown
07-29-2003, 04:52 AM
Just curious what the the speed limiter is set at on a 1990 RS 305 TBI? my speedo does not work and it shuts down, at what speed i do not know, any help would be appreciated.:confused:
speed limiter?etslbrown 07-29-2003, 04:52 AM Just curious what the the speed limiter is set at on a 1990 RS 305 TBI? my speedo does not work and it shuts down, at what speed i do not know, any help would be appreciated.:confused: 87DJP2001 07-29-2003, 08:18 AM My guess with a RS and it did not come with speed rated tires V/Z the limit should be 115 MPH. TheGreatJ 07-29-2003, 08:32 AM When I had the TBI305 in my '91 RS it would shut down at 115. So yeah, DJP is correct. Black6SpdTA 07-29-2003, 10:10 AM Yup, 115 here check this out: http://www.thirdgen.org/newdesign/tech/unlimited.shtml -Rippin mikey dragster 07-29-2003, 05:36 PM MY 91 TBI CUT'S OUT AT 117MPH AT 4,400RPM'S IN OD OR AT 117MPH AT 6213RPM'S IN DRIVE. BUT UNDER MY TBI I GOT A 350. OR RATHER HAD A 350 NOW ITS GOINT TO BE A 406. 87DJP2001 07-29-2003, 06:25 PM Originally posted by mikey dragster MY 91 TBI CUT'S OUT AT 117MPH AT 4,400RPM'S IN OD OR AT 117MPH AT 6213RPM'S IN DRIVE. BUT UNDER MY TBI I GOT A 350. OR RATHER HAD A 350 NOW ITS GOINT TO BE A 406. Who cares, the question has been answered.:rolleyes: mikey dragster 07-29-2003, 06:29 PM NO NO NEW QIESTION WHY IS THE PONTIAC'S LIMITER SET 2MPH HIGHER THEN THE CHEVY'S.??????????????? CHEVY CAMARO 115 V.S.PONTIAC FIREBIRD 117. BOTH ARE TBI'S.?????????? Fast_B4C 07-29-2003, 06:43 PM I dont have a speed limiter and it says RS on my car??????:metal: Zepher 07-29-2003, 06:54 PM Originally posted by Fast_B4C I dont have a speed limiter and it says RS on my car??????:metal: Maybe cuz you have a B4C option. It's probably 117 on both Chevy and Pontiac. Speedos aren't that accurate at high speeds anyways. mikey dragster 07-29-2003, 06:57 PM yeah that's what i figured. there both set at `117mph. 92BLKL98 07-29-2003, 06:58 PM Originally posted by Rippin92RS Yup, 115 here check this out: http://www.thirdgen.org/newdesign/tech/unlimited.shtml -Rippin Not intended to flame anyone or third gen.org but: I am a big fan of thirdgen.org but to me the guy who wrote this as well as thirdgen.org dropped the ball on this one. Wouldn't it be a cleaner job to just remove the speed limiter in the memcal. If you have a buddy with a prom burner and the software it is very simple to do. The limit set at the factory on the cars with Z rated tires at an unobtainable 255 mph. Black6SpdTA 07-29-2003, 07:00 PM Both are set at 115. At 100+ mph, speedo's arent perfect. You were probably only going 115 even if it said 117. -Rippin Black6SpdTA 07-29-2003, 07:01 PM Originally posted by 92BLKL98 I am a big fan of thirdgen.org but to me the guy who wrote this as well as thirdgen.org dropped the ball on this one. Wouldn't it be a cleaner job to just remove the speed limiter in the memcal. If you have a buddy with a prom burner and the software it is very simple to do. The limit set at the factory on the cars with Z rated tires at an unobtainable 255 mph. It would be cleaner but if you don't have a buddy with the stuff, well then it's no so easy. And if you have the switch somewhere like under the dash, I think it'd be pretty cool. Either way though... -Rippin Zepher 07-29-2003, 07:07 PM It's easy to reprogram the TBI cars since the chip isn't in a large holder like the TPI cars and the later V6's. I reprogrammed my friends 91 TBI Bird when he went from 2.73 gears to 3.42. He'd hit the limiter at 92mph since the ecm was still reading 115-117 due to the gears. Fast_B4C 07-30-2003, 12:50 AM Originally posted by Zepher Maybe cuz you have a B4C option. It's probably 117 on both Chevy and Pontiac. Speedos aren't that accurate at high speeds anyways. Hahaha Yah thats true doug791 07-30-2003, 01:40 AM a tpi 350 wouldnt have a speed limiter would it? Ive never taken the car over 120 mph so i wouldnt know. etslbrown 07-30-2003, 02:57 AM Just want to say wow! thanks for responding with so much info, i am glad i found this site....:cool: lots of amazing info on here, i will be back to ask more ?'s in the near future....till then keep'em between the ditches:D robvas 07-30-2003, 08:57 AM The TPI cars will hit 140. Originally posted by doug791 a tpi 350 wouldnt have a speed limiter would it? Ive never taken the car over 120 mph so i wouldnt know. mikey dragster 07-30-2003, 03:17 PM Originally posted by Rippin92RS Both are set at 115. At 100+ mph, speedo's arent perfect. You were probably only going 115 even if it said 117. -Rippin . WELL AUCCUALLY IT READ 117MPH BUT I WAS DOING 122MPH.WITH 4.11 GEARS WITH 295/50d15 HOOSIER'S.SO IT WAS TURNING 4,400 RPM'S IN OD. MY91Y84 07-30-2003, 08:17 PM Originally posted by robvas The TPI cars will hit 140. yup..143 in my g92 LB9..i coverd 12 miles in 5 1/2 minutes and im guessin 150 or so drafting a L98 vette it was cool as hell...i "felt" the car start pulling harder once i pulled in behind him the speed limiter was determined by the tire rating...but you guys knew that lol Garage Inc. 07-31-2003, 12:33 AM Originally posted by mikey dragster . WELL AUCCUALLY IT READ 117MPH BUT I WAS DOING 122MPH.WITH 4.11 GEARS WITH 295/50d15 HOOSIER'S.SO IT WAS TURNING 4,400 RPM'S IN OD. really..... mikey dragster 07-31-2003, 01:18 PM yes really ain't that so cool when corrected the speedo toi the 4.11 i swear i go send the sending unit for shorter tires but 295's are 26.6inches tall instead of the stock 25- 26 inches depending on if there 16's or 15's. 235/55r16's = 25ish 215 65r15's = 26ish. chevyman502bb 07-31-2003, 09:51 PM ive owned my camaro for about 6 hours now (lol).....my s10 cuts out at 97ish....i didnt even think about a limiter being on a camaro at all! the ASE chip gets rid of the limiter in my s dime, is there a chip available to do the same thing in my 88 camaro? ps....if i say something retarded in the future its because i dont know too much about camaro's.....i know some but not much..........my bro has an 87 trans am and i end up teaching him about his own car, i know maro's and f birds r very similar but ya know how gm screws things round when they sell a car under a diff name......this is y i say i dont know camaro's that well......thanx again and please...HAVE PITTY!.......lol j/p | ||
