lordmetalz28
07-28-2003, 10:40 PM
got a question here my air foil should i be worried about some of my gasket falling into my tb im going to change the gasket anyway so when i peel it off do you think itll stick the top or the throttle body if so how do i do it without removing my throttle body
slayer6x6
07-28-2003, 11:15 PM
You dont need to remove the throttle body to install an airfoil, its placed on the front. The only tool you need is an 8mm wrench. If you are going to change the gasket, then you will need to scrape the gasket off (a razor works best).
oh and by the way punctuation and capitalization help because when someone reads your post it is easier for them to understand otherwiseitbecomesabigmessofwordslikethis;)
