Ok, 3 weeks ago, my car wasnt starting too good. It would turn over real slow, then a lil faster then a lil faster........so on....and then finally start. Well, I figured my altenator was bad, so I replaced it, and it worked. Everything was back to normal. Then yesterday, and started doing it again. And today it got even worse. Ok so lets eliminate the possibilities.
1. I have a brand new battery(forgot to mention that)
2. New Altenator(actually a rebuilt one from O'reilly's.
3. I dont think it's the starter, cause like I said, after the new altenater, everything was back to normal.
So what's the deal?
slayer6x6
07-28-2003, 10:14 PM
Sounds like the starter is going to me, I would keep a hammer in your back seat just incase you need to give it a little pursuasion when it decides to stop working on its own.
5litre_eater
07-31-2003, 11:26 PM
I have a 88 Camaro with a 305 TBI, and my Stater just recently went. Only it would just click everytime I turned the key, and then after a few tries, would start up. But yeah, keep the hammer like he said and if it won't start, give it a few whacks.
2000TA
07-31-2003, 11:30 PM
Sometime starters act funny they will work fine than give you trouble than work fine again I would go with the starter
Slow91z
08-01-2003, 12:16 AM
Yeah starter, is where I'd go...Is it worse when it's hot?? like it's been running and the engine is warm, you turn it off and let sit for like 5-10 min. and then it's hard to start, classic starter symptoms.
slayer6x6
08-01-2003, 03:04 PM
Yeah, usually happens when you have headers but, I had mine jet hot coated and never had starter problems :knocks on wood:
Slow91z
08-02-2003, 12:12 AM
My car would do it in completely stock form...with a stock thermostat and fan switch, If I cooled it down it would probably help.
aklim
08-02-2003, 07:58 PM
Sounds like the starter. I have never had a problem with mine even when I had headers and a stock starter. Since I had my 383, I have used the gear reduction starter that you get in the Chevy catalog of go fast parts.
