Ragtop-87
07-28-2003, 02:23 PM
Just something else with the car stalling, When I turn the A/C on the car does not idle up like others do. I am wondering if this would have something to do with my problem. The A/C works fine. Again Thanks for all the help.
jconrad
05-09-2004, 10:25 PM
If the car does not idle up like it is supposed to, that is an IAC problem most likely.
aklim
05-10-2004, 07:25 AM
Take the entire TB off and remove the IAC and the IAC housing and clean them all off with brake cleaner andreinstall and reset lile pricedure in TGO
Ragtop-87
05-10-2004, 07:30 AM
Thanks for the info. It was the IAC somehow it had come unscrewed. I replaced it with a new one and it is working fine. Again THANKS
aklim
05-10-2004, 11:31 AM
Still, you should clean the TB and the IAC and adjust the IAC when you are done.
