Help me fix my miss, it's my only car!
Old Jul 27, 2003 | 10:16 PM
Jared95Z's Avatar
My 95 z has a weird stutter/miss under about 2900 rpm under full throttle. as soon as it hits 2900 rpm or so everything seems normal. I checked the fuel pressure, its good, plugs and wires have less than 20,000 miles on em. it confuses me that it fixes itself anfter a certain rpm. Any help is GREATKY appreciated, Thanks.
Old Jul 27, 2003 | 10:42 PM
JSK333's Avatar
A lot can happen to plugs and wires in 20K miles. Make sure none of your wires have been burned or rubbed through from the pulleys on the pass. side.
I replaced two bad wires and all my plugs and my low end stumble and running rich went away. The wires had about 15K miles on them and the plugs... about 4-5K.
Old Jul 27, 2003 | 11:23 PM
cals400ex's Avatar
i also say check the plugs. you could see if there is any sparks flying at night under the hood too. this would probally mean you burnt one of your wires. it possible that a plug could even have come a little loose.
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
