car wont start after tb install
Old Jul 27, 2003 | 01:25 PM
MattysTA's Avatar
any one have this problem? its a52mm bbk i have everything hooked up right and the tps sensor is seeing.71 volts with the key on and at wot is at around 3.89 volts but she doesnty want to start. the pcm is also not throwing any codes. any ideas?
Old Jul 27, 2003 | 01:44 PM
ChickenScreamer94's Avatar
Is it even cranking? Just give a little more info. Is your iac hooked up? Did you make your own gasket or did you buy one? I ask that since if you made one you might of forgot to make the third hold for the IAC passage (at least i always thought that was what it is for)
Old Jul 27, 2003 | 01:59 PM
MattysTA's Avatar
well it turned out to be something stupid while i was moving around my cai to get the elbow off or back on my coil wire that is spliced into for my maft translator became unplugged. i plugged it back in and she fired right up. seems to pull a little harder mid to top end now. but one of those gaskets didnt seal to well i think cause i did some scanning and shes running a little lean now. this tb makes my cai sound like it has a small blower on it now lol you can hear the air getting pulled in harder thanks for the reply anywa.........
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
