Who makes this part for the F-body? I've only seen it for the Vette's.
I need this part RIGH HERE The stock one on my Z had a hole in it. The prev. owner used Nitrous and stuck the jet in there. I've coved the hole, but would like to replace the part.
I'd like to think I'm gaining more HP, but I want something that will work, and looks better. I'm trying to find one that will fit my Z in red, but I haven't had any luck yet.
I found this one at Mid America Designs.com. They seem to be on the pricy side, but then again, so is everything for a vette.
thank you.
Milo
<font face="Verdana, Arial" size="2">Custom C5 Air Coupler Replace your 1997-2001 Corvette's stock rubber accordion coupler, which rests between the throttle body and intake duct, with our custom silicone Air Coupler. Its smooth surface allows air to flow much smoother, producing less turbulence, yielding 3-5 more horsepower! Requires only minutes to install.</font>
thank you.
Milo
I also found the part at:
Breathless Performance.com - but not in red, and I still don't know if it will fit.
i do believe slp makes them for the fbodies it is called a high flow bellows.
98 Z28, Onyx Black, A4, t-tops, other than the free mods, a random tech cat back, and a whisper lid, it is stock
<font face="Verdana, Arial" size="2">Originally posted by 1sloLS1:
i do believe slp makes them for the fbodies it is called a high flow bellows.</font>
I did some looking on slp, and here is the part: High Flow bellows Part# 23065. Its $49.95 plus $10 dollars shipping. I'll have to order it when I get paid.
Thanks 1sloLS1!!
Milo
The Fernco is the cheapest way to go.
There is also a single rib style just like the SLP type that goes for $12, now if I could only remember who it is that carries it.
A search on LS1.com would pull it up, that's where I saw it.
Dave
Dave
Or you could get the "Camaro Hose" from http://www.bakerprecision.com/ You can get it in red if you want. $30 You need to call them to order it, it's not on their web site. You have to do a little bit a of trimming to get it fit but nothing major. I have a blue one. Pic below.
http://www.home.ix.netcom.com/~rob.h...FIPK_Right.jpg
'02 SS #2878
Current Project - 82 El Camino recieving an LT1 from an Impala SS
INLAND EMPIRE F-BODY ASSOCIATION
'02 SS #2878
Found it...
$12.80 for a bellow identical to SLPs, requires minor trimming.
http://shop.airflowonline.com/Merchant2/merchant.mv?Scree n=PROD&Store_Code=AFSI&Product_Code=40R35SL&Catego ry_Code=HH
Dave
[This message has been edited by ratio411 (edited August 19, 2002).]
Dave
- Dynomouth Exhaust!
- My 98...318 rwhp/334 ft lbs
- Mesh Grille
- 71-74 Emblems
- Clear Corners
- My New Home Page
- mn55927@citlink.net
The only problem with the Fernco 4x3 (no rib) version is the tendency to crack lids due to no flexibility. I tried it for a week and got rid of it. It also made my lid and MAF sit slightly higher, causing it to bang againt the SS scoop (I think this latter item depends on how you hood sits, as fitment varies between cars).
Ratio411, if you can find the single rib at a plumbing store for $12 let me know!!
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Diff. cover, SY3500, SLP LS6 Intake, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, BMR SFCs, G2 DSL, Nitto 555R, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
I've had a Fernco 3"x3" on my car for 3 years... with none of your issues.
I posted the link for you... $12.80 for a single rib.
The Fernco 3.5"x3" is also an option, but is an odd size and hard to find.
Dave
Dave
<font face="Verdana, Arial" size="2">Originally posted by ratio411:
Found it...
$12.80 for a bellow identical to SLPs, requires minor trimming.</font>
Found it...
I just ordered 3 of them. One for me and 2 more because someone with WTFBA will see mine and want one.
One of the guys with WTFBA had one of these that someone gave him, but he never did find out where it came from. Now we know!
Thanks again!
Dave</font>
Dave</font>
Found it...
Dave
</font>
Found it...
Dave
</font>
I just received the 3 that I ordered and they are the wrong size. The 3.5 inch fits over the MAF without any problem, but the 4" end it frikkin' HUGE. It is WAY too big for the throttle body.
I measured my TB ... it is 3 15/16, but the outer lip makes up 1/16, so the TB itself is only 3 7/8. This hose is actually about 4 1/16 inner diameter, making about a 3/16" gap to fill.
I did manage to fit the 3.5" end to the throttle body with only a minimal amount of work. I didn't even have to heat it up. This hose stretches very easily. I worked the hose for about 5 seconds and slid it over the TB.
So, I just called AirFlow Systems and am returning the 4" - 3.5" reducer hump hose and am ordering the 3.5" - 3.5" hump hose.
[This message has been edited by rncotton (edited August 27, 2002).]
Sorry about that! Glad you let us know... That is the one that they themselves recommend, right at the bottom of the pic in the link it says it is for Camaro/Firebird. I did think the measurements weren't quite right, but I thought maybe they measured it differently.
Sorry again, glad they are doing a swap.
Dave
Dave
I was unfortunate enough to use that link and buy the bellow without paying much attention. And of course it didnt fit the TB.
Oh well, at least it was only like 20 bucks after shipping.
Bentley
2000 Camaro SS M6
Direct-Flo Air Lid w/ K&N
HPP3, 160 Thermo
Flowmaster w/ !cats
Ported MAF, Free Ram-air
Trimmed EGR
Oh well, at least it was only like 20 bucks after shipping.------------------
Bentley
2000 Camaro SS M6
HPP3, 160 Thermo
Flowmaster w/ !cats
Trimmed EGR
