Some more GTO info.
crYnOid
07-23-2003, 09:29 AM
Over at the car and driver forum they have a board called 'Ask the Expert' and currently Bob Kraut is the expect and is talking a little about the GTO. He did a rather large update today but I will post the good bits ;)
http://www.caranddriver.com/idealbb/view.asp?topicID=36731&sessionID=3CF4D87A2D604F6AAA15E7071217337F
Q: Next question, since we are on the topic of transmissions: Will the new 5-speed be available in the GTO? (I do not want to start a whole new topic.)
A: No. The manual transmission in the GTO is the same Tremec close-ratio six-speed available in the Corvette ZO6. The automatic will be a specifically calibrated 4L60-E four speed. These are the only transmissions for the 2004. Will things change in the future? All things are possible.
http://www.caranddriver.com/idealbb/view.asp?topicID=38044&sessionID=3CF4D87A2D604F6AAA15E7071217337F
Q: What will be the gto accessories?
A: We working on several possibilities, including rocker panels and other body moldings, a hood with scoops, and a rear fascia with two exhaust ports, that could be available as soon as the first part of 2004.
:eek: :bow: :D
http://www.caranddriver.com/idealbb/view.asp?topicID=37585&sessionID=3CF4D87A2D604F6AAA15E7071217337F
Q: Why does both exhaust pipes come out on one side of the car, and not split like on most dual exhaust cars?
A: It was a timing and money trade-off. Porting the pipes to the same side allowed us to use some of the Monaro’s original rear fascia. We are investigating offering a rear fascia with two exhaust ports as an accessory in early 2004 and we are actively looking at something different for the 2005 model.
But, I don’t want you to get hung up on the where the two pipes exit the car. The GTO does have a true dual exhaust system with separate cats, mufflers, and resonators, no mixing of gases from manifold to exhaust tips.
http://www.caranddriver.com/idealbb/view.asp?topicID=38103&sessionID=3CF4D87A2D604F6AAA15E7071217337F
Q: 1. I've visited the Holden web site and the HSV web site as well. Many of the first GTO photos showed HSV rotors as opposed to the stock Holden units. Will the GTO have the brake system and suspension from the HSV vehicle?
A: The HSV version is an aftermarket, upfitted car created by Holden Specialty Vehicles, a separate company from Holden. It contains a lot of extra parts and would cost upwards of $50,000 if sold in the U.S.
The GTO will feature four-wheel disc brakes with a Bosch 4-channel, 4-wheel ABS system. This configuration is consistent with the current Monaro.
Q: 2. Why is the manual transmission an "extra cost" option? A GTO is a driver's car not a Blvd runner - the option should be for the auto. Shame on GM for charging extra for the 6-speed - That, in effect, is an underhanded way of lowering the base price. I'll wager that the majority of GTO's will be ordered with the 6-speed. BTW, the Crossfire comes standard with a manual, and costs extra for the 5-speed automatic.
A: The basic reason the manual transmission is an extra change is that this particular manual costs a whole lot more than the automatic (kind of a change from years past, huh?). The Tremec T56 six-speed, close-ratio manual transmission offered in the GTO is not your average manual. It’s the same high-performance unit found in the Corvette ZO6.
Q: 3. Will the GTO have the basic amenities that the Holden offers? (i.e., driver seat memory, identical multi-function computer, etc.)
A: The GTO will offer many of the same amenities offered in the Holden Monaro, including a driver information center and powered memory seats. , standard leather seating, keyless entry, steering wheel controls … and the list goes on. The GTO will not have memory seats however.
Q: 4. Since Callaway supplies HSV with higher output LS1 engines, will you Pontiac guys "persuade" Reeves to allow GTO buyers to purchase CNC heads rebuilds?
A: I can’t speak for Callaway, but there are a lot of performance parts already on the market for the LS1 V8 found in the GTO, so you should have no problem finding ways to enhance your performance.
And, by the way, I hope you enjoy your new GTO.
http://www.caranddriver.com/idealbb/view.asp?topicID=36615&sessionID=3CF4D87A2D604F6AAA15E7071217337F&pageNo=2&num=20
"Sir, will GM offer the higher performance LS-6 V8 as well as the current LS-1, say, in a future higher-performance model (like the old Judge, which Matt mentioned)?"
We’re not closing the door on the possibility of a “performance-model” of the GTO, but right now we are concentrating on the 2004 model with the LS1 engine. Stay tuned, because the one thing I know for certain is that this car is going to be around for a while, and it’s going to evolve.
Q: Until there is some real-world usage of cylinder deactivation (in automobile) using GM's current system, I (and I suspect many others) will consider another overly complex and intrusive way to exploit the EPA's outdated and farcical mileage requirements. Effectively losing half your cylinders while still requiring them to be accelerated along with the rest of the reciprocating mass, as well as requiring each dead cylinder to compress and return the trapped air (effectively acting as a spring) is not what any engineer outside the corporate culture of GM would consider effective, efficient or elegant. Also, doesn't the added mass of the pushrod-disconnect (not sure of the proper term) in turn require stiffer valve springs, and therefore more loss due to the valvetrain even when all eight cylinders are firing?
A: The electronic Displacement-on-Demand system you are describing actually works amazing well on the vehicles I have driven. However, the GTO will NOT have a displacement-on-demand system.
Magnum Force
07-23-2003, 10:21 AM
excellent insight!!:cool:
muckz
07-23-2003, 10:36 AM
So will it, or will it not have the memory seats?
crYnOid
07-23-2003, 10:47 AM
I think he may have ment power seats that have no memory.
99SilverSS
07-23-2003, 10:51 AM
Good info and what I expected to hear. GM is trying to do this car with the least amount of change and added costs as possible. The fact that they may have aftermarket add on body parts available says to me SLP may be involved or if nothing else GM is getting the hint the car needs a few more visual keys to help it.
The T56 with ratio's from the Z06 is nice to hear showing that this car is getting the best parts available and not some hand me down stuff the F-cars got used to getting.
1990 Turbo Grand Prix
07-23-2003, 11:00 AM
Though I like the new GTO alot, I feel some key ingredients are missing that could be added other than the dual tips and scoops. Most of GM's line up in available with XM radio, GTO is not. And whereas I'm used to having an open roof, whether it be a sunroof or t-tops, the GTO has no open roof option at all.
Magnum Force
07-23-2003, 11:42 AM
Has the suspension been stiffened at all? or is it a complete carry-over? anybody have any predictions on how well the GTO will handle?
muckz
07-23-2003, 11:51 AM
Does GTO have an H pipe? It sounds pretty good.
Ude-lose
07-23-2003, 11:58 AM
what i can see is that the GTO is more commodore SS spec where the Monaro is more Berlina/Calais spec, its how they kept the price down (no memory seats, no climate, 17" rims etc etc.
what i can see though is the money they have spent, is on performance/power/handling , i think the americans will be shocked, as well as the aussies which aren't accustomed to GM's "power ratings",
lol then the aussies will b*tch- "hey why don't we get that at the same price ??!!!" ;)
DarthIROC
07-24-2003, 01:23 AM
Did GM ever quote a price on what the 2004 GTOs will go for?
Odin
07-24-2003, 01:26 AM
hmm we can get a HSV GTO for about 49000 USD :D It seems to have enough features :)
Ude-lose
07-24-2003, 04:33 AM
observe-
http://www.chipmaster.com.au/images/MWS_EATON2.jpg
IZ28
07-24-2003, 05:00 AM
He pretty much said everything I wanted to hear. :) Sounds better, it's gonna be nice when all the good stuff happens sometime in 04/05 and on.
Evilfrog
07-24-2003, 05:28 AM
If it the T-56 costs so much more the the 4L60-E, way was it a free option in the F-bodies. (or am i missing something?)
Ude-lose
07-24-2003, 05:36 AM
what you're missing is that there is two versions(maybe more) of the t56, the first in the f-bods and c5 is called the NM6, and the other is the M12 which is used in the Z06(and maybe viper?) , it has closer ratios, and has tripple synchromesh (no more rubbery knotchy feeling on the shifts)
Z28x
07-24-2003, 07:15 AM
All this information sounds great, If I was going to get a GTO I wouldn't be able to get one until next spring and by then I'll be able to get a hood with scoops and pipes coming out on both sides, probably as a dealer installed option.
GM has a winner with this one. :thumb:
Ted 99 TA WS6 Conv
07-24-2003, 08:10 AM
Did you mean MN6? This is the RPO that corresponds to the GTO's six speed. No mention of an M12 RPO!
Ted
Ted 99 TA WS6 Conv
07-24-2003, 08:13 AM
I looked at the Vette RPO's and they have two RPO's of MN6
LS1 Engine, 5.7L LS1 V8 SFI
LS6 Engine, 5.7L LS6 V8 SFI
MN6 Transmission, 6-speed manual
MX0 Transmission, 4-speed automatic
So the MN6 for the GTO could mean anything!
Ted
Ted 99 TA WS6 Conv
07-24-2003, 08:15 AM
Here's the GTO RPOs
A88 Seat headrest, front and height adjustable
AH8 Seat adjuster, power driver and front passenger
AK5 Air bags, frontal
AQ9 Seats, front and rear sport bucket
B58 Floormats, carpeted, front and rear
C60 Air conditioning, manual single zone
C95 Lighting, lamp interior roof
DL6 Mirrors, outside rearview, power
FE2 Suspension, Sport
FE9 Emissions, Federal requirements
G80 Limited slip differential
JL9 Brakes, 4-wheel antilock
K30 Cruise control
LS1 Engine, 5.7L V8 SFI aluminum
NB8 Emissions override, California, Massachusetts, New York or Vermont
NC7 Emissions override, Federal
NE1 Emissions, Maine, Massachusetts, New York or Vermont state requirements
NP5 Steering wheel, adjustable
PZ9 Wheels, 17" x 8" (43.2 cm), 5-spoke aluminum
QWN Tires, P225/50R17-93W, blackwall
T43 Spoiler, rear
T82 Headlamps, auto-on/off,
U1X Sound system, 6-disc CD changer
U77 Antenna, in-glass
VK3 License plate cover, front
YF5 Emissions, California state requirements
Ude-lose
07-24-2003, 08:25 AM
a screen capture from pontiacs website - click here (http://www.micro-op.com.au/execls1/m12.jpg)
Ted 99 TA WS6 Conv
07-24-2003, 08:27 AM
Hmmm so it is a m12 .... very interesting!
Ted
Jason E
07-24-2003, 08:43 AM
The biggest oversight on GM's part, indeed, is this :( I mean, everything from a Sunfire to a Bonneville has (and on my lot, sells much better with) a power sunroof. All my Grand Am GTs, all my Grand Prixs, always have one. And now a $35,000 car without one? Sure, Mustang doesn't have one either...but Mustang does not cost as much on average...
A true shame :rolleyes:
Ude-lose
07-24-2003, 09:05 AM
did you guys see this?
http://www.pontiaconline.com/index.html
Ude-lose
07-24-2003, 09:24 AM
or these ?
http://www.d2alio.com/gto/black2.jpg
http://www.d2alio.com/gto/black3.jpg
http://www.d2alio.com/gto/black4.jpg
http://www.d2alio.com/gto/black5.jpg
http://www.d2alio.com/gto/black6.jpg
http://www.d2alio.com/gto/black1.jpg
Z28x
07-24-2003, 01:11 PM
Ude-lose, what size rims are on that Black GTO? The show car had 18" and production is getting 17" right? I was hoping the GTO would be getting 18" rims, the 350z and G35 have 18"s
Jason E, the Cobra is $35,000 and has no sun roof, but I agree with you, it should be an option.
guionM
07-24-2003, 01:49 PM
I think we can safely state "Performance is not dead at GM".
I think I can also safely say that many of you will be in for a small surprise very soon. :D
07-24-2003, 02:14 PM
How soon is soon in your book, Guion? NAIAS?
guionM
07-24-2003, 02:28 PM
I suspect there may be something at NAIAS we'd be very interested in. But as far as info, I'd be very surprised if we are still in the dark at the end of September, let alone NAIAS.
Just a hunch. ;)
Meccadeth
07-24-2003, 02:40 PM
OK...WTF is goin on?? (http://web.camaross.com/forums/showthread.php?s=&postid=1032214#post1032214)
In that thread, Branden also hinted that 'big news' should be expected in september...
A 5th Gen Camaro is pretty close...one approval away really. I hope to have a pretty big update in September
Joe K. 96 Zeee!!
07-24-2003, 03:03 PM
And I've been all set to wait years for more info...
I'd rate this more exciting than a new toaster for sure!! (see MT 5th gen Camaro thread)
91_z28_4me
07-24-2003, 04:27 PM
The reason that XM is not available on the GTO is that it is essentially a Aussie Monaro which would have no need for XM, only available in the Lower 48 states. Since this is a rush job and the first Holden to come to the US I don't think that XM was on the top of the list but hey if you want it just have it installed with a RF modulator.
HuJass
07-24-2003, 04:57 PM
observe-
VERY NICE!!! :thumb:
SNEAKY NEIL
07-24-2003, 05:19 PM
Just a hunch. ;)
So is this surprise going to be a Chevy?......................I think I am getting all excited.
By the way, those are really nice pics of the GTO. I like that car more and more. The black really looks good
Meccadeth
07-24-2003, 05:21 PM
Black Metallic! :D I can't wait to see that color, I've never seen a Black Metallic car before, at least not knowingly.
Evilfrog
07-24-2003, 05:57 PM
Thank you.
IZ28
07-24-2003, 11:59 PM
Looks like we'll be getting some 5th Gen Camaro news soon huh. :cool: I hope it's all good stuff. :)
I like that the GTO rims aren't 18's because IMO that's too much, but I don't like what they did to the design of the middle of them, they should've left them like they were on the Show Car. That was just unnecessary.
