how hard is n2o on the stock rearend
Old Jul 21, 2003 | 03:47 PM
zuluman13's Avatar
As subject says is n20 safe on a stock rearend?
Old Jul 21, 2003 | 05:44 PM
Hawk's Avatar
broke mine on a 100 shot.
Old Jul 21, 2003 | 08:37 PM
Nitrous Crazed's Avatar
Depends if you are running slicks or not. If you launch on the nitrous with a six speed the days are limited. I had an Auto launching on a 100 shot.It held up but I had traction problems. 60ft was a 1.89. I used the TA-Girdle and stud kit to make it last.
Now I have a 9 inch.Cant wait to leave on trans brake.
Dave
Old Jul 21, 2003 | 08:44 PM
zuluman13's Avatar
im gonna use dr and im not gonna launch on nitrous ill have a window switch for probably 2500 rm the lowest and it will be a 150 shot
Old Jul 21, 2003 | 10:05 PM
Hawk's Avatar
150 shot, your rears days are numbered, plan on a 9" or a 12 bolt.
Old Jul 21, 2003 | 10:06 PM
zuluman13's Avatar
would a t/a rear girdle help
Old Jul 22, 2003 | 03:30 AM
Wild1's Avatar
On my stick, I plan on shooting only 100 in 3rd, 4th, and possibly 5th. Got 4.10s and an Eaton Posi, can't get traction in 1st anyways.
Old Jul 22, 2003 | 08:30 AM
Derrick Redd's Avatar
Sorry to say but a M6 + sticky tires + 150 shot = Rears usually last awhile with A4's because of less drivetrain shock. I'm still running a 10-bolt in my car.
Old Jul 22, 2003 | 01:53 PM
mikebanx's Avatar
can you please exlpain what a twelve bolt is , also what a 9" is. please
Old Jul 22, 2003 | 03:18 PM
D James's Avatar
its a stronger rear end, if you count the lug bolts on your stock rear there are 10 a 12 bolt has twelve. The gears are bigger and hold more power heres an article about the two http://www.carcraft.com/techarticles/1038/index.html
The only downfal of these rear ends are the price, look to pay at least 2000 bucks for a complete asembly
Old Jul 22, 2003 | 03:19 PM
Sparkz28's Avatar
a twelve bolt is a GM rearend that was used in older muscle cars and Gm trucks....it can take a hell of a *** kicking with no problems...
a 9 inch is a ford rearend and will hold just about whatever you can throw at it
the 12 bolt vs 9 inch is a toss up.....9 bolt will hold a tad more power..but the 12 bolt cost less money
Old Jul 23, 2003 | 10:23 PM
mikebanx's Avatar
thanks alot for your replies,
Old Jul 26, 2003 | 04:15 PM
rpm4lalo's Avatar
I use a 150 wet shot in 2nd, 3rd, and 4th gear at the track. I have Nitto Drags on the 10 bolt with 4.11 gears.
I think that if I ever sprayed in 1st gear with slicks, the ring gear would snap the instant the clutch engaged.
Besides I am having a hard time hooking up with drag radials and 4.11 gears just with the power the motor is making NA.
Old Jul 26, 2003 | 04:49 PM
zuluman13's Avatar
how do u spray in only a certain gear i thought it was just a wot switch and a window switch
Old Jul 26, 2003 | 06:02 PM
Wild1's Avatar
You can add another button in series that only works when pressed. So, it is like adding another safety switch in the series.... could be a thumb button or another micro switch.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Jlo
Feb 3, 2015 09:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
