vortec
Old Aug 12, 2002 | 10:24 PM
skrolle66's Avatar
Post vortec
does the lt1's or the ls1's come with vortech heads....? oh, and i was just wondering ....could you take a classic 327 and put an lt1 or ls1 intake manifold on it? just sort of use the 327 block and and all of the other electronics etc. from the newer engines ?
Old Aug 13, 2002 | 09:54 AM
Pro Stock John's Avatar
Post
LT1 = has LT1 heads
LS1 = has LS1 heads
My 99 Tahoe (96-99) = has L31 5.7 iron block with factory Vortec heads
LT1 and Vortec stuff is more likely to interchange.
LS1 stuff is completely different and will only interchange with LS6/ Zo6, and truck stuff.
1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM
Old Aug 13, 2002 | 11:11 AM
Freak's Avatar
Post
To make things more confusing, all the 3rd Gen engines (including the LS1/LS6) are called Vortec engines by GM. But the Vortec heads everyone talks about wont interchange
Old Aug 13, 2002 | 04:40 PM
skrolle66's Avatar
Post
but doesnt the vortec mean the same thing as honda's v-tech? variable valve timing, to give more power at what ever rpm you are at? instead of just having one rpm range that has the most power...and having dead spots in the power band?
Old Aug 13, 2002 | 07:58 PM
phil1001's Avatar
Post
not even close, the gen III smallblock doesn't have that nor does anyother engine gm has made, and nothing from the genIII SB interchange to the older smallblock.
2000 black WS6 6speed
318 RWHP 322 RWTQ stock
best et: 12.72 with the et streets. 60' 1.81
bestmph: 109.72 first time out, no mods, on the street tires
Mods: centerforce dual friction clutch, moser 12 bolt w/4.10's
BFG dragradials, PRO 5.0 shifter
whats next: put the borla on, take baffles out of WS6 hood, tb bypass, et streets
[This message has been edited by phil1001 (edited August 13, 2002).]
Old Aug 14, 2002 | 04:29 AM
PhantomTA's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by skrolle66:
but doesnt the vortec mean the same thing as honda's v-tech? variable valve timing, to give more power at what ever rpm you are at? instead of just having one rpm range that has the most power...and having dead spots in the power band?</font>
NO
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
Old Aug 14, 2002 | 10:36 AM
Post
no
Hal Fisher
Sep 30, 2015 09:03 PM
1995Blackz28
Jul 20, 2015 09:34 AM
dfarr67
Apr 10, 2015 07:44 PM
Chris Anderson
Jan 27, 2015 08:30 AM
99huggerorangeZ
3rd Gen / L98 Engine Tech
Dec 11, 2002 11:51 PM
