Grrr, more turn signal woes
Old Aug 10, 2002 | 06:04 PM
T/A Punk's Avatar
Post Grrr, more turn signal woes
Ok this is making me feel a little rediculous. Finally got around to replacing the burned signal bulb I had (front amber, underneath the headlights not side marker). Works fine, everything is ok...except it still won't blink. Rear lights are fine so that isn't causing any trouble, I can't think of anything that would cause the bulb to function normally yet not flash. Is there something that needs to be reset that I'm missing? Lol, I did't think something so simple could make me feel like a dumbass .
Old Aug 11, 2002 | 11:16 AM
AU_98TA's Avatar
Post
Have you tried replacing the Blinker Fuse?
Old Aug 11, 2002 | 01:18 PM
ru2slo_99's Avatar
Post
Have you checked the blinker fluid yet? j/k You should check the relays and the fuse.
Old Aug 12, 2002 | 11:32 PM
T/A Punk's Avatar
Post
Well, tried swapping the hazards fuse and the blinker fuse with no luck. hazards still worked and the left blinker still stuck so it's not the fuse itself. could something have fried in the fuse box possibly?
Old Aug 13, 2002 | 11:14 PM
T/A Punk's Avatar
Post
ttt
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
