Thought my converter was stock but...
Old Jul 19, 2003 | 12:37 PM
Timberwolf's Avatar
When I pulled the trans today..the converter is PINK!
Anyway to ID it? There is a date and 4L60E written on it in marker. The only thing I can find on it is "D9" repeated all the way around the perimeter. It's stock diameter I believe.
Old Jul 19, 2003 | 04:36 PM
Timberwolf's Avatar
ttt
Old Jul 19, 2003 | 07:06 PM
95 Silver TA's Avatar
You might want to call Precison Industries they make the Vigalente converter. I believe thats what you have there. Mine is a vig too and its also pink. I dont remember any number painted on it though but I could be wrong.
Hope that helps a little,
Claude
Old Jul 19, 2003 | 07:14 PM
Forgot to mention if it is a vig, you are LUCKY cuz they cost a little over 700 bucks and can withstand upto 1100 HP.
Here is the website http://www.converter.com
And here is there phone numbers
Reg Ph# 800-649-7866
Tech Ph# 901-466-0267
Thx,
Claude
Old Jul 19, 2003 | 09:15 PM
Timberwolf's Avatar
thanks, I've had a vigi before, but it was a 10". I am not sure if this is a vigi or if it's a restalled stock converter. I have heard SLP used colors to designate stall speed.
I'd like to find out what stall this converter is, since the trans goes back in tuesday and I have to decide between putting this back in or the 2400 yank I have...
Old Jul 20, 2003 | 08:06 PM
Timberwolf's Avatar
Does ANYONE know anything about converters? I have to decide which converter to put in by tomorrow! Please HELP!
Old Jul 20, 2003 | 08:48 PM
burnemonm1's Avatar
personally I can really feel the difference in my buddy's TA
Old Jul 20, 2003 | 09:29 PM
AHARTZ28's Avatar
if its pink it is probably a pricision industries stock sized converter or someone did your trans before and painted it pink ..
Old Jul 20, 2003 | 09:32 PM
Timberwolf's Avatar
Is there any way to tell what stall it is?
Old Jul 20, 2003 | 09:36 PM
AHARTZ28's Avatar
take it to a trans shop maybe they can or put it in the car and see what it stalls. see if it has a stall number on it or any numbers and call vig.
Old Jul 20, 2003 | 09:40 PM
Timberwolf's Avatar
The only thing it says is "D9" all the way around it
Old Jul 20, 2003 | 09:46 PM
AHARTZ28's Avatar
those are probably the stampings from when they tore it down its like a marker
Old Jul 20, 2003 | 09:55 PM
Timberwolf's Avatar
so should I go with my yank 2400 and sell the pink mystery converter?
Old Jul 21, 2003 | 07:06 AM
AHARTZ28's Avatar
if you have the $$ then buy it and find out what the one you have is, then sell it if its a vig.
Old Jul 21, 2003 | 07:59 AM
Timberwolf,
I just called Precision Industries, They said they dont know what that D9 Stands for but they said if its a Vig converter it will have a part number stamped on the converter on the Flywheel side.
Hope that helps,
Claude
