MSD Dig 6 VS. Tranny Tach signal
Old Jul 17, 2003 | 07:46 PM
Fastbird93's Avatar
Ok, on the 93 T/A I just bought, it has a 95 M6 in it. This is due to the car being originally an auto. So, WITH a MSD Digital 6, the tach was showing the right signal, says the former owner. Without, like it currently is in my possession, the tach gets nothing. Why would this be, and can anyone give me some insight?
Old Jul 19, 2003 | 07:00 AM
Fastbird93's Avatar
TTT, come on, someone's got to know something........
Old Jul 19, 2003 | 07:24 AM
revtime's Avatar
Try and give us some more insight to what the problem is, I am not understanding.
Your saying it does not have the MSD box anymore and you need to get a tach signal?
Old Jul 19, 2003 | 07:59 AM
Fastbird93's Avatar
Yeah, the car does not have the box anymore, and when the box was taken out, the tach lost the correct signal. When the car starts now, the tach will initially come up to about normal idle, but when revved, the tach drops down and bottoms out instead of acting normally. With the digital 6 box, the previous owner said it acted fine. I know there's a tach filter, and that's connected to the coil, but I'm wondering why the stock system wouldn't pick it back up when the box was removed.
If it helps, it's a 93 car, and a 95 M6.
Old Jul 19, 2003 | 08:14 AM
revtime's Avatar
well it sounds like its trying to pick it up but not getting good connection. I would check all the wires going to the coil and make sure one is not loose, I am not sure which one exactly is the tach wire, maybe someone will get on here and tell us.
If the tach is reading idle initially then I would think its just a loose connection.
The MSD box was plug and play wasn,t it? No wires were spliced or anything?
Old Jul 19, 2003 | 08:21 AM
Fastbird93's Avatar
Yeah, plug and play. I have a service manual, and have already identified the wire, pulled it from the coil, double checked it, and found nothing out of the ordinary.
Old Jul 19, 2003 | 08:54 AM
revtime's Avatar
Bad Ground?
Old Jul 19, 2003 | 10:53 AM
Fastbird93's Avatar
I don't think so. If it was a bad ground, the tach shouldn't show anything at all. I'm getting a Dig 6 for it anyway, but it bugs me right now that I can't watch the tach, and there's no rev limiter either.
wesley81
Jul 27, 2015 11:31 AM
colts0455
Jul 24, 2015 04:51 PM
88IROC_Z
Jul 22, 2015 11:38 PM
GT what?
Jul 14, 2015 10:17 PM
