Amp, turns off when A/C turns on?
DrDUKE
07-17-2003, 02:11 PM
What do you think about that?
Just started, used to work fine. Evey thing is hooked up correctly.
slayer6x6
07-17-2003, 02:32 PM
Where did you run your remote turn on wire from? Get a voltmeter and test the voltage at the remote turn on wire when the AC is off, then turn it on and see what reading you get. Post back with the results.
