jd94z28
07-16-2003, 01:33 PM
Can you still pass emissions?
Anyone in Indiana remove the EGR Valve?jd94z28 07-16-2003, 01:33 PM Can you still pass emissions? stik6shift93 07-16-2003, 02:43 PM You should pass the sniffer no prob, the only thing you'd have to worry about is if they have a visual inspection. Alucard 07-17-2003, 02:17 AM since when do we get tested for emissions?!? jd94z28 07-17-2003, 11:23 AM I'm in Lake county. I believe we do here. jd94z28 07-17-2003, 11:28 AM I just checked emission testing is required for Lake, Porter, Clark and Floyd counties. Zig'sbird 07-18-2003, 12:38 AM Not sure if you could do this but I have family out in AZ who did this trick... Can you get a PO box in a county that does not have e. checks and register your car in that county so you won't have to worry about it? boosted3.8 07-26-2003, 10:50 PM heres another little trick, block off the egr(weld it shut) on the manifold. Then everything is still there for the visual;) | ||
