355, Moser 12 Bolt, Denny's Driveshaft, McLeod Street Twin and much more for sale!
Old Jul 15, 2003 | 11:49 PM
Speeds8erM-1's Avatar
355, Denny's Driveshaft, McLeod Street Twin, Weld Draglites and much more for sale!
I am selling almost everything I have for my 94 Z28. E-Mail if there is something you want, dont post here first, I will see an E-Mail before I will see a post here. The prices are firm unless otherwise listed, I am already taking a big loss on all this stuff. I accept PayPal, money orders and cash. I will only accept PayPal credit card payments on the 355 and 12 bolt. I will only ship to the lower 48 states unless we work something out. I have this stuff for sale local also, so keep that in mind.
355 LT1 Shortblock, Bored .030 Over, Honed, Balanced by Jessie Holmes, I have the balance sheets, Resized Rods, Crank turned .010/.010, TRW Forged Pistons, ARP Rod Bolts, Speed Pro Rings Gapped a little bit for nitrous, Clevite 77H Rod and Main Bearings, Clevite Cam Bearings and Brass Freeze Plugs. The way it is balanced, we used a different weight on the Street Twin Flywheel to get it in spec without having to use more mallory metal. I dont know how it would work out with another flywheel, it should work, I will include the weight we used on the flywheel. Brand new. Never been run. $1200 plus shipping or I will deliver within 100 miles
McLeod Street Twin Clutch, this is an older one that didnt come with an adjustable master cylinder but comes with everything to make it work, this is how people did it for years. Brand new. Never been run. Sold
Flowmaster Catback with Flowtech Cutout and Resonators, it has been welded, so it would have to be cut to ship, $140 plus shipping
Intrax Lowering Springs, brand new spring isolators for the rear $110 plus shipping
McLeod Billet Adjustable Master Cylinder for LT1's and LS1's. Brand new. $210 shipped
95 Timing Cover, comes with new gasket, $40 plus shipping
2 AC Delco 4 Wire O2 Sensors. Brand new. $75 shipped
Fel-Pro Header Gaskets, $9 shipped
Voltblaster. Brand new. $55 shipped
Stock LT1 Balancer and Hub, surface rust from getting wet and sitting, $25 plus shipping
Centerbolt LT1 Valve Covers, passenger side has a Billet Metco Push In Breather Adapter, Sold
Map Sensor, $8 shipped
Lifter Retainer, $5 plus shipping
Mr Gasket Carburetor Studs, Chrome V Belt Pulley, Moroso Big Block Chevrolet Water Pump Spacer missing some pieces, two Hyundai Rear View Mirrors, two Ford Emblems, MSD Blaster 2 Coil Wire for HEI, TD Chrome Dual Carburetor Feed Line, $4 plus shipping
Camaro Dash Plaque for 97-2002's, $4 shipped
Clutch Master Cylinder and Slave Cylinder sold
Water Pump, it was on the junkyard engine, so I dont know if it works, the housing is still usable for sure, $25 plus shipping
LT1 Radiator, has the typical wear, still has hoses hooked to it, $90 plus shipping
LT1 AC Condenser, has the typical wear, $50 plus shipping
Old Jul 16, 2003 | 09:12 AM
RealQuick's Avatar
How much for shipping to 02718 for the 12 bolt? Who set it up?
Old Jul 16, 2003 | 10:24 AM
JodyJ's Avatar
Sent you mail on the following parts:
MSD Timing Retard Box with timing retard chips. Brand new. $95 plus shipping
Voltblaster. Brand new. $60 shipped
Fel-Pro Header Gaskets, $8 plus shipping
Thanks,
Jody J.
Old Jul 16, 2003 | 10:56 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: 355, Moser 12 Bolt, Denny's Driveshaft, McLeod Street Twin and much more for sale!
Originally posted by Speeds8erM-1
[B]
Two Map Sensors, $8 shipped each
Chrome LT1 Emblem, $4 shipped
B]
I'll takem both
email me adn i'll mail you a check of some sort
Old Jul 16, 2003 | 10:57 AM
RealQuick's Avatar
sent you mail on the 12 bolt and injectors
Old Jul 16, 2003 | 11:06 AM
xxsaint69x's Avatar
you have mail about the 12 bolt.
Old Jul 16, 2003 | 11:07 AM
95TA8280's Avatar
Dibbs in the head gaskets....
And YGM about the 355.....
Old Jul 16, 2003 | 12:02 PM
cformulaowens95's Avatar
sorry to highjack do all master cylinders work for both LT1 and LS1? i've been searching for this answer for a while.
Old Jul 16, 2003 | 03:02 PM
Timberwolf's Avatar
can you check shipping on the tank and fuel pump to 49017?
Old Jul 16, 2003 | 06:03 PM
I am going to make something clear, not to be an a$$hole but my prices are low, I am losing enough as it is, please dont try to hit me with any really lowball offers.
treyz28, sent you an E-Mail.
Everybody else, I replied.
Timberwolf, it's still in the car, let me see if I can get it out tonight and see how much it weighs. It will probally have to be shipped freight.
Old Jul 16, 2003 | 11:39 PM
Rearend, injectors and a map sensor are sold. Everything else is still for sale.
Old Jul 17, 2003 | 12:18 AM
madwolf's Avatar
Is the 355 a shortblock or long block or complete engine?
Old Jul 17, 2003 | 12:43 AM
lt1orls1igotbot's Avatar
Talking 12 bolt
How much for the 12 bolt?
Old Jul 17, 2003 | 01:39 AM
KyleBlue85Iroc-Z's Avatar
As long as everything works, I'm interested in the Blaster Coil and one of the temperature sensors. I'm going to send an email.
Kyle
Old Jul 18, 2003 | 12:51 AM
Ion, it's a shortblock. Your glovebox is on the way.
lt1orls1igotbot, check the post, I sold the rearend.
Kyle, the coil is brand new in the package, the temp sensors, one was on my car and worked along time ago, the other, came on a junkyard engine but should be fine. E-Mail me if you want to get everything setup.
