Vortec Intakes
Black6SpdTA
07-13-2003, 10:40 AM
With Vortec heads, the only intake I could find are the 2 Edelbrocks, GMPP, and SDPC TPI intake. So I could run TBI (w/ adapter) or TPI. Is there anyway to "Ram" (SuperRam, StealthRam, MiniRam, etc.) a vortec headed motor?
-Rippin
TheGreatJ
07-13-2003, 11:49 AM
I believe you can use the SuperRam with the Scoggin-Dickey TPI base. The Miniram and StealhRam won't work because the ports don't match up.
Ski89Z28
07-13-2003, 12:27 PM
I think TPIS (http://www.tpis.com/) , miniram manufactures, now make a miniram to match up to Vortec heads or GMFAST Burn heads, don't know if they are the same.
Chuck!
07-13-2003, 12:58 PM
Yea the miniram 3 is vortec compatible.
AutoRoc
07-13-2003, 02:35 PM
GM Makes their own RamJet EFI manifold. You can get it in kit form which includes:
Intake
LS1 throttle body
fuel rails
fuel pressure regulator
injectors
knock sensor
distributor
and some other sensors, maybe MAP and MAT, not sure
It runs around $1100-$1300 If I remember right:D
That's my plan, I have Edelbrock E-Tec 200 heads which are Vortec pattern. Goodluck!
