scanmaster won't start
streetbad
07-13-2003, 02:01 AM
Red wire is 12v, black is ground, white is 4.5v or 4.99v. It won't start ,what are steps to take? I am Lost. Tim
turbo_Z
07-13-2003, 03:14 AM
01 02 03 04 05 06 07 08
09 10 11 12 13 14 15 16
this is what your 16-pin connector looks like... just imagine. you want the red wire at 16, black wire at 04 and white wire at 09. hope that helps.
streetbad
07-13-2003, 10:57 AM
Thank You Turbo Z!, I have had the wires there. Not working yet. On the circut board the white wire is in the green wire hole. Their is no green wire.
turbo_Z
07-13-2003, 03:19 PM
alright then try the white wire at 14 and see what happens. i have my scanmaster set up like i mentioned before but then my tuning cable has white at 04, black at 05 and green at 14.. reds still in 16.
96speed
07-13-2003, 03:57 PM
IMO, its a better idea to use power and a ground from somwhere else if you are hardwiring the scanmaster.
99% of the time its one of those $0.02 connectors as the culprit!
Ryan
