How to Disable PE mode?
96speed
07-12-2003, 08:47 PM
How do you disable PE mode with LT1edit?
Ryan
rskrause
07-13-2003, 10:01 AM
Ryan
Depends exactly what you want to accomplish. But if you zero out the PE tables that will prevent any fuel from being added.
Rich Krause
JSK333
07-13-2003, 04:47 PM
In TunerCat there is a "MAP WOT Enable" constant. I imagine there is something similar in LT1_Edit.
It is a constant of how much MAP is required before PE mode can be entered based on throttle position.
It's set to 15kpa stock. So just set it a good bit over 100 and you'll never enter PE.
